17-12-2013, 12:31 AM
What happened with the headgasket?
karl1989 black ph1 boost bus roof opinions
17-12-2013, 07:57 AM
Radiator doesn't want to bleed up. Going to have another go after work. What is this worth to people
Venetian XUD ph2 heaven
Ph3 perv cab heaven Black ph1 XUD died Moonstone hdi stage 2
17-12-2013, 08:45 PM
Brand new thermostat dodgy, 2nd one out of the spare block still pressurised so took the thing out. Temps at 70 witch is good but should the top hose still get quit hard?
17-12-2013, 09:02 PM
Sounds like similar problem that I've got. I'm going to try a thermostat but I think its more likely HG
Should get firm but not rock hard lad are heaters red hot?
The more higher temps get the warmer the heaters. Not loosing water and no oil in water
Also when I hit boost it drops like 3 psi in 3rd-4th
27-12-2013, 05:31 PM
Not updated for a while
[attachment=12280] [attachment=12281] [attachment=12282] [attachment=12283] [attachment=12284] [attachment=12285] [attachment=12286]
Ph3 perv cab heaven Black ph1 XUD died Moonstone hdi stage 2 |
| Karl1989 moonstone HDI | karl1989 | 85 | 35,866 |
09-04-2014, 09:18 AM Last Post: karl1989 |
| karl1989 black ph1 boost bus | karl1989 | 3 | 2,921 |
22-08-2013, 02:57 PM Last Post: karl1989 |
