I may have the answer to our stage 2 clutch woes.
#31
Bigger turbo, longer spool time, produces less lower down torque.. More clutch friendly :p
Limit the torque down low, put the power down higher in the RPMs...
Bonus?
Though everyone seems dead against this...
#33
But the torque spike at the boost threshold will be greater with a bigger turbo, won't it? And you can only go so far up the range before it becomes difficult to stay in the power band thanks to the HDi's long gearing, that has always been my reasoning.
Is this a company based in Bradford by any chance??
I was so close to ordering a cg paddle but it worked out around the same as the Sachs paddle plate... that coupled with the poor customer service nd patronizing emails a while back when a lad had problems with the clutch on his HDI and helix wanting £500 for a full paddle to hold 300lbs+ along with the heaviness I didn't leave myself much choice
Saying that, the Sachs still hasn't arrived, they told me 10 days, I rung on day 11 to be told its still been manufactured in Germany.
Be interesting to know the prices and torque ratings.
S2 HDi >click<
154bhp
280lbs/ft
#35
Right sorry ive not got back to you on this, not too happy with this tbh, ive been expecting a phonecall for 2 weeks now.
Ive called them 3 times now but im still waiting for the illusive "dan" to get back to me about it.
The bloke I spoke to when I first enquired was more than helpful and seemed eager to help but after that they dont wanna know.
If he does get back to me ill let you know how it goes.
Oh and no mate they are in bristol iirc
#36
Boggo Sachs sprung paddle with a boogo Valeo pressure plate held my 285lbft fine, and I was really giving that some grief.
It lasted 40k/4yrs too by the looks of it.
Even a NEW LuK clutch kit will take 275lbft if you have a bit more turbo lag (full standard system with back box) for a year, with only slight slipping.
You really don't need anything crazy.
I'm pretty sure that £180 Sachs Berlingo kit is the answer to all your prayers too. If it's the one people have bought (they never seem to be able to say for deffo), then it'll hold 275-285lbft ok for years too.
I didn't think the clutch selections we had now were a big issue, I thought the main issue was cost.
I don't get why Helix now have uprated pressure plates AND paddles, since I've put over 300lbft through mine on a Valeo pressure plate and it was still feeling like it was biting VERY hard on engagement. They are stupidly expensive too.
There are two issues. Friction coefficient (materials), pressure (pressure plate)...
In my experience just adding friction (cerametallic paddle) is all you need to do. The Sachs one will give 275lbft+ for years of hard use and abuse, not that juddery all said and done, and £200.
Dave
#37
I was wanting to try the berlingo clutch but its hard to find a Definitive answer.
I was looking at the uprated helix pressure plate (£210) and using a boggo friction plate but again dont know if it'll work.
#38
I have a berlingo plate for sale...
Got to admit the berlingo kit itself does look and feel like good quality, the cover is definately heavier, the plate doesnt look like anything special but still i have a valeo clutch in my boot and as a kit it feels looks much better imo. Mines getting fitted as i type so il let you know how heavy it feeels on the pedal
S2 HDi >click<
154bhp
280lbs/ft
#39
Where did you get it from? Csn you post s link or something.
What hsve you done then berlingo cover and valeo plate?
#40
I am now running a full stage 2 remap I ended up buying a cg 5 paddle Motorsport clutch for 275 pound + postage and I got to says its awesome its really light holds the full power and I was quite worred because people was telling me that paddle clutch are on\off but it's really not that bad I can pull away fine there is a little bit of a snatch but I've only noticed it on a very steep hill but still can pull away fine I really recommend it!!
#41
You have to ring online automotive mate. Part numbers are on quite a few threads. Ive gone for thats sachs race paddle plate and used sachs berlingo cover and release bearing
This paddle is super light, but its got a funky biting point, really snatchy... It seems to holding the torque already, first couple of miles it slipped something silly tho
S2 HDi >click<
154bhp
280lbs/ft
#42
How much it cost you all in?
#43
Check my project mate I shove most of my updates in there... not the cheapest but seems to be workibg
S2 HDi >click<
154bhp
280lbs/ft
  HDI starting woes.... cully 5 4,360 15-04-2018, 08:53 AM
Last Post: Mighty306
  Oil brether woes dr_jekyll 8 6,757 01-02-2017, 04:57 PM
Last Post: dr_jekyll
  Best clutch for stage 2 L16rye 4 4,734 15-11-2016, 06:36 PM
Last Post: Poodle
