The Racetractor. The End. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Photos and Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=20) +--- Forum: 306 Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=3) +--- Thread: The Racetractor. The End. (/showthread.php?tid=8415) Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - ADV_93 - 15-08-2014 What is the difference between a 2.1 and a 1.9? Excuse me for asking i've never heard of a 2.1?! RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 15-08-2014 2.1 is 2088cc and the 1.9 is 1905cc RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - ozonehostile - 15-08-2014 (15-08-2014, 12:27 PM)ADV_93 Wrote: What is the difference between a 2.1 and a 1.9? Excuse me for asking i've never heard of a 2.1?! Essentially the same block as the xud9, just longer stroke, slightly bigger capacity, main difference is the 12v head RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 15-08-2014 Different block I believe isnt Ozone?? RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - ozonehostile - 15-08-2014 (15-08-2014, 03:24 PM)Piggy Wrote: Different block I believe isnt Ozone?? Yeah it's different but essentially the same, just slightly taller, slightly different little bits and pieces like the bottom coolant hose size, taller, different crank etc Similar, just everything slightly bigger Re: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - mcglynn - 15-08-2014 Piggy I had this exact problem, the stamping on the clutch pedal is a great idea in theory, BUT if anyone else has seen the thickness (or rather lack of it) of the pedal stop then they wont stamp on the clutch and let it slip off again. I got stuck in bolton when I was doing it. The stop had bent so much my pedal sat too high for me to fit my work boots between it and the fuse box, and it also allowed the cable to slip off the retaining hook on the pedal as it wasnt at enough of an angle any more to grab & hold the clip. Luckily I had a spare clutch pedal box but im 95% sure thats your problem. RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 15-08-2014 Ive bent it back a little and managed to rebuild, so to speak, the adjuster in the cable. Bite is high but driveable now RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - mcglynn - 15-08-2014 Dont go slipping your foot off the clutch again as I assure yoy the metal stop is weak as piss RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - jammapic - 15-08-2014 Do you mean the little stop that sticks out of the metal housing at the top of the physical pedal's travel? RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - mcglynn - 16-08-2014 Remember I sent you the photo if the whole metal bracket broken..that part RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 16-08-2014 Spent hours trying to find the fault with the arduino...tidy loom now a mess...different batteries...stand alone power for the arduino...new earths, different relays.......... traced to an earth fault somewhere.... Finally found what seems to be a faulty arduino board. Theres a dirty earth on it somewhere as soon as you power it up. No obvious circuit fault on the board...but its defo there. and buggering all the sensor values up...main one being the RPM. things not going well....found lots more rot on the 206 too this evening. Plus my cheap nasty MIG been buggering me about. then the jacking point collapsed on me as I called it a day at 9pm in the dark. not been a good day RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Jimbo - 16-08-2014 Sounds like a bad week for you mate Sure things will turn soon RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 16-08-2014 Im trying to stay positive. I HATE rust and welding it all up. Most hated job. So once its all done...i will feel better. I'm guna make this 206 proper nice so Im still positive about it Oh yeah and once I get this flipping arduino stuff working, that be nice too! RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - procta - 17-08-2014 piggy whats this engine like for spare parts? as its not a common unit if I am right, also did it slot straight on to the 306 mounts? bear with me like, as I am not cluded on up on French engine conversions. RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 17-08-2014 Bolts straight in on mounts They came in 806, 406, xantia, XM and something else I cant think the name of. Alright for parts. Depends what you mean by parts? Most of the stuff on it is xud9! RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - procta - 17-08-2014 it was spare parts but you have answered that tbh, when you said they are alright for parts. RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 17-08-2014 Well like blocks,heads, sumps are easy to come by. Tricky to find the manifolds I want as there were variations. Ordered a new arduino R3 board. Hoping that sorts it RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 17-08-2014 [video=youtube]http:// http://youtu.be/0PIuP2c-1xw[/video] RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - mcglynn - 18-08-2014 Seems a new board may well be your best bet, hope it works! RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Dum-Dum - 18-08-2014 (17-08-2014, 03:56 PM)Piggy Wrote: Bolts straight in on mounts Peugeot 605 RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 18-08-2014 Ah yeah...synergie tol RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Dum-Dum - 18-08-2014 Well if were going to be picky here you can add the Citroen BX to that list and the Lancia Zeta and the Lancia Phedra RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 18-08-2014 You sure the BX had the 2.1? RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Dum-Dum - 18-08-2014 Pretty sure. Edit, just googled, I knew they did a 2.1 BX but it isnt an XUD11 Also did you know that the NA XUD11 has a bore 1mm larger than the turbo ones. RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 18-08-2014 Aye its bigger RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - ash23 - 19-08-2014 this link may be of use to you two ? Although its abit far http://m.ebay.co.uk/itm/301283047122?nav=SEARCH RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 19-08-2014 Nice one ash...messaged and texted him! RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Dum-Dum - 19-08-2014 Thats a bargain at a £50 starting bid. Mine is slowly getting there but rain has again stopped play. RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - andyyy - 19-08-2014 Have you tried reflowing the board ? Might be worth it if its knackered anyway unless you have warrenty Ahh ignore me I missed you've ordered one RE: 2.1 GTd...CG clutch & GTB FITTED & RUNNING!!! - Piggy - 19-08-2014 Ozone having a look. Supplier is sending one too...so I will have at least one spare I guess. Be good to have one to play with anyway to work out my own writing software etc |
