TD04 Progress - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: TD04 Progress (/showthread.php?tid=5485) Pages:
1
2
RE: TD04 Progress - londondan86 - 20-08-2012 Dont suppose you have a link, the stuff ive been looking at on ebay is only up to 750* F. Will that be enough? ( http://www.ebay.co.uk/itm/Car-Van-Truck-Trailer-GREY-Gasket-Sealer-Sealant-Maker-High-Temperature-700F-/180865176055?pt=LH_DefaultDomain_3&hash=item2a1c6791f7 ) RE: TD04 Progress - CJ_Derv - 20-08-2012 This is the stuff i get from local motor factors and seems to be fine pal http://www.ebay.co.uk/itm/GRANVILLE-200ml-HIGH-TEMP-INSTANT-GASKET-RED-WITH-FREE-POSTAGE-/370607223846?pt=LH_DefaultDomain_3&hash=item5649e97426 but i get black this is red and a bit pricey RE: TD04 Progress - londondan86 - 20-08-2012 Nice one mate, that link you put up is max 650* so the other one should be fine. RE: TD04 Progress - CJ_Derv - 20-08-2012 (20-08-2012, 03:16 PM)londondan86 Wrote: Nice one mate, that link you put up is max 650* so the other one should be fine. Yeah should be fine matey if mines lower and holds well that will be fine
RE: TD04 Progress - Mattcheese31 - 20-08-2012 (20-08-2012, 02:24 PM)CJ_Derv Wrote: This is the stuff i get from local motor factors and seems to be fine pal i buy granville stuff sometimes . . it's locally made i think Ponti or somewhere close . .
RE: TD04 Progress - CJ_Derv - 20-08-2012 its definitly good stuff the manifold gasket on block is actually leaking atm since fitting think turbo need nipping up a tad since it getting hot going to get it warm n try nipping up as its blowin a tiny bit from block gasket but turbo seems to have held really well and taken some real abuse recently |
