I'm back....GTIDI inside - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Photos and Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=20) +--- Forum: 306 Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=3) +--- Thread: I'm back....GTIDI inside (/showthread.php?tid=23559) Pages:
1
2
RE: I'm back....GTIDI inside - Pompey306mark - 04-05-2014 I cut my 5 door slam panel to go over the rad. Loads of pics on here. RE: I'm back....GTIDI inside - strictly_perv - 14-05-2014 So managed to get a full day on the car yesterday Front end off ![]() ![]() Front mount on ![]() Little bastard spraying oil everywhere ![]() ![]() Luckily had a new one lying round so fitted that Also wired in a slimline fan to the original wiring so it comes on with AC button and fitted a new glow plug relay as it had packed up and some new solid linkages. RE: I'm back....GTIDI inside - ginge191 - 14-05-2014 Looking good; hows it driving now; heaps better than before?? RE: I'm back....GTIDI inside - nominous - 14-05-2014 ![]() Going to betray my lack of 306 knowledge here, but why can you not go to the left of the rad with the return pipe from the IC rather than the convoluted route ? What is in the way which isn't on the other side ? RE: I'm back....GTIDI inside - anto - 14-05-2014 The end tank of the rad prevents it from going that route. RE: I'm back....GTIDI inside - Dum-Dum - 14-05-2014 That is a fair old route mate lol. Suppose its no worse than mine though RE: I'm back....GTIDI inside - Poodle - 14-05-2014 That's some pretty chronic extra piping there, got to be worth taking it through the washer bottle space and relocating that instead, surely. RE: I'm back....GTIDI inside - bashbarnard - 14-05-2014 Or up through slam panel and mod that. Less lag. Plus ure blocking half the engine cooling Nice.motor though I'm back....GTIDI inside - Sambarker - 15-05-2014 Or run a ph2 rad with expansion tank seperate to get a bit more room down the side of the rad on the o/s RE: I'm back....GTIDI inside - Dum-Dum - 15-05-2014 I suppose at least it's ally pipe on the run back so will give some extra cooling RE: I'm back....GTIDI inside - MissTap_GTI6 - 15-05-2014 Don't get him started on 'extra piping'
RE: I'm back....GTIDI inside - zx_volcane - 15-05-2014 much pipe I'm back....GTIDI inside - devils_fuel - 15-05-2014 Yay she's back
RE: I'm back....GTIDI inside - rd070707 - 15-05-2014 Can I ask how you wired the fan to rhe AC button? Id like to do it on mine with a slimline RE: I'm back....GTIDI inside - Niall - 15-05-2014 It will be bloody tight getting the angle there but you can just get a pipe through between the expansion tank and the lower pipe inlet. I'm back....GTIDI inside - Sambarker - 16-05-2014 (15-05-2014, 07:52 PM)rd070707 Wrote: Can I ask how you wired the fan to rhe AC button? Id like to do it on mine with a slimline You bridge two pins on an a/c plug which means when you press the ac button it turns the fans on. There's a thread about it RE: I'm back....GTIDI inside - strictly_perv - 16-05-2014 I figured out when I got the slam panel back on and everything urged in the I can easily route a pipe between the rad and slam panel. So I will be getting that sorted next for more direct piping Yes what SamBarker says, very easy job and most of the time the AC doesn't work in 306's anyway so we may as well put it to use. RE: I'm back....GTIDI inside - Piggy - 16-05-2014 Search Cullys helpful threads...re:AC button to fans Good work there mate, top effort, does seem a long way mind!! If you look at my thread, I cut back my slam panel and went over top too. My top of rad leabs back about 10mm too RE: I'm back....GTIDI inside - Carlos182 - 16-05-2014 (16-05-2014, 09:10 AM)Piggy Wrote: Search Cullys helpful threads...re:AC button to fans Can't seem to find it, blame being on mobile though :p RE: I'm back....GTIDI inside - bashbarnard - 06-07-2014 Just out of intrest how do you go about insuring things like this? Also tax and logbook stuff? Might reshell mine into a phase 3 hdi at some point RE: I'm back....GTIDI inside - Uberderv - 07-07-2014 (04-05-2014, 08:07 PM)Niall Wrote: That much Nice welding ![]() ^^^^^ Nialls adapter. |
