Getting more poowwwaaaaa!! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Getting more poowwwaaaaa!! (/showthread.php?tid=1940) |
Re: Getting more poowwwaaaaa!! - Dum-Dum - 04-03-2012 I reckon itll be the pipe off the turbo. Is your boost gauge actually accurate? Re: Getting more poowwwaaaaa!! - Tom - 04-03-2012 I have no idea i just bought a cheap one on ebay lol is the pipe easy to get off? Re: Getting more poowwwaaaaa!! - 4WayDiablo - 04-03-2012 its a bit of a bitch to get to that pipe, take off the airbox intake side of things from after the BMC round to filter and get into it from that way easiest ive found Re: Getting more poowwwaaaaa!! - Tom - 04-03-2012 So reaching down the back of the engine and feeling for the jubilee? Re: Getting more poowwwaaaaa!! - 4WayDiablo - 04-03-2012 youll be able to see it might need a torch or something but its there Re: Getting more poowwwaaaaa!! - Tom - 04-03-2012 Ahhhh ok will pull that off when i get some time this week, inbetween getting the exhaust done :p RE: Getting more poowwwaaaaa!! - declantg - 04-03-2012 Could the pipe from the turbo itself be loose? Re: Getting more poowwwaaaaa!! - Dum-Dum - 05-03-2012 tomw1123 Wrote:I have no idea i just bought a cheap [boost gauge] one on ebay lol This could be your issue, my last HDi had a cheap ebay gauge and it was reading 21psi but actually only making 17.5psi so thats about 15% out no reason why it couldnt be your gauge being partly to blame. Re: Getting more poowwwaaaaa!! - 4WayDiablo - 05-03-2012 So dum how can you tell what it is actually making as opposed to what the guage says? Re: Getting more poowwwaaaaa!! - Mattcheese31 - 05-03-2012 4WayDiablo Wrote:So dum how can you tell what it is actually making as opposed to what the guage says?buy a half decent one? .. Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 Anywaay lets not go off subject here.. I had that pipe off today from the turbo to the intercooler and nothing looks fine to me bar 2 little nicks but im pretty sure they were my fault anyway pictures to follow Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 Re: Getting more poowwwaaaaa!! - declantg - 05-03-2012 they are in better condition than mine are mate, should be fine Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 Balls.... I didnt think it was bad either just in my mind i wanted that to be the problem so i could fix it and have power lol.... gotta go put it back together yet and i dropped a jubilee down the back of the block somewhere Re: Getting more poowwwaaaaa!! - declantg - 05-03-2012 tomw1123 Wrote:Balls.... I didnt think it was bad either just in my mind i wanted that to be the problem so i could fix it and have power lol.... gotta go put it back together yet and i dropped a jubilee down the back of the block somewhere I know this feeling bud dont worry, will all be sorted soon so keep at it Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 We're running out of pipes to check haha Re: Getting more poowwwaaaaa!! - declantg - 05-03-2012 Have you checked your inlet manifold? Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 What you mean by check lol i tightened all the bolts i could get at :/ Re: Getting more poowwwaaaaa!! - declantg - 05-03-2012 Has it got a gasket on it? Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 Yes i can see its got a gasket. Re: Getting more poowwwaaaaa!! - declantg - 05-03-2012 Have you got a top mount or a fmic, cba to scroll up Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 I have a top mount... the d seal is air tight im sure of that the only things left are: That pipe wasnt sealed around the turbo properly I just tightened the end manifold bolt a whole turn could of been that or it could be my extremely bodged up T for my boost gauge Re: Getting more poowwwaaaaa!! - declantg - 05-03-2012 If its your boost gauge T piece you will be hissing like a b*tch. More than likely if the pipe wasnt sealed on to the turbo properly then there you will be gushing out boost Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 It does hiss.... Re: Getting more poowwwaaaaa!! - declantg - 05-03-2012 have you put clamps on the t piece? Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 Yes but i dont have a proper T i hose that goes to the gauge is bodged with cable ties and electrical tape... You reckon i could get a 6mm silicon hose over an 8mm pipe?? Re: Getting more poowwwaaaaa!! - declantg - 05-03-2012 Yeah, heat it up a bit then stretch it over Re: Getting more poowwwaaaaa!! - Tom - 05-03-2012 Right all back together went for a drive and no change :cry: so new T piece and new hose on the way so i can rule that out then we'll see whats happening :/ silly peugeot Re: Getting more poowwwaaaaa!! - Dum-Dum - 05-03-2012 4WayDiablo Wrote:So dum how can you tell what it is actually making as opposed to what the guage says? When they plug it in on the dyno as the one on the dyno is calibrated. |
