td not starting - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: td not starting (/showthread.php?tid=1024) Pages:
1
2
Re: td not starting - londondan86 - 22-01-2012 Before taking the pump off completely. Try taking off and cleaning out the delivery valves. The spring could be stuck? Edit: Did this 11mm pump work originally? Re: td not starting - Blaze tub tom - 22-01-2012 Yea she's worked a beaut.. It's only in the last week she slowly lost power then just wouldn't start and created that knock (don't no if uv seen the video) how do I go about doing that dan? Re: td not starting - liam doidge - 22-01-2012 sounds like something lose in the pump :S mine did that when it died somehow the cold start spring came off and was at the bottom of the pump :/ Re: td not starting - londondan86 - 22-01-2012 Hopefully its not something loose inside but that cant be rulled out I'm afraid! The delivery valves are on the end of the pump, the metal fuel lines attach to them. Crack them off 1 at a time (14mm) and check that everything is as it should be, spring still in position, etc. Re: td not starting - Blaze tub tom - 22-01-2012 Ok cool cheers dan uv been a big help so far il let u no tommoro wen I finish work what I find Re: td not starting - londondan86 - 22-01-2012 Blaze tub tom Wrote:Ok cool cheers dan uv been a big help so far il let u no tommoro wen I finish work what I find No worries bud! Re: td not starting - Blaze tub tom - 23-01-2012 Ok took the dvs out and cleaned very carefully put back in place and tested.... F***ing thing won't work at all now!!!! Ahhhhhhhhhhhhhhhhhhhh I hate French cars!!!... Anyway rant over! Took the pipes of the dvs and thers no fuel coming out at all so my question is now... If these our transit dvs on my pump can I just get another pump of a trannie and swap the dvs straight over?? Re: td not starting - londondan86 - 23-01-2012 Blaze tub tom Wrote:Ok took the dvs out and cleaned very carefully put back in place and tested.... F***ing thing won't work at all now!!!! Ahhhhhhhhhhhhhhhhhhhh I hate French cars!!!... Anyway rant over! Took the pipes of the dvs and thers no fuel coming out at all so my question is now... If these our transit dvs on my pump can I just get another pump of a trannie and swap the dvs straight over?? You need the 306 dv's not the tranny ones! Re: td not starting - Blaze tub tom - 24-01-2012 oh.. ok forget that then lol do these have a lift pump or electric pump in the tank? Re: td not starting - londondan86 - 24-01-2012 Blaze tub tom Wrote:oh.. ok forget that then lol do these have a lift pump or electric pump in the tank? Neither. The Bosch has a vane pump built in that draws the fuel from the tank. IIRC Darren pup a pump in his tank to help the VE keep up with the revs. Re: td not starting - Blaze tub tom - 24-01-2012 Right how would I check if it's drawing? Re: td not starting - londondan86 - 24-01-2012 If there is no fuel coming out at all check your stop solenoid. Take it out, remove the spring and plunger then screw it back in. Remember you will have to stall it off if it starts Re: td not starting - Ruan - 25-01-2012 Who did this 11mm pump? Re: td not starting - 4WayDiablo - 25-01-2012 Ruan Wrote:Who did this 11mm pump?We dont know. The owner before but dunno where it origionated from Re: td not starting - Blaze tub tom - 25-01-2012 When I bought if off the previous owner it had a krisB sticker on the back so I assuming kris done all the work.. Iv checked the solinoid it clicks in and out but il check that on Friday as the battery is now completely screwed. |
