any tips for removing ecu plug pins
as above anyone got some tips, tricks and tools for removing the pins from the loom plug on the single socket ecus
remove the screw, pull the inside section out, pull out the coloured slider keeper things out, then the pins will come out quite easily.
most of the later ones have a bit of rubbery plasticy crap moulded on the end which you'll need to remove.
What he said ^^^^^^& Seem to remember they had a little tab which needs to be retracted for removal.
  Swapping 3 plug to 1 plug bashbarnard 6 2,419 25-02-2017, 05:16 PM
Last Post: bashbarnard
  Engine cover pins Hdi and proud of it 11 4,081 24-03-2015, 09:57 AM
