Swapping 3 plug to 1 plug
So i might have a spare engine but its got the wrong loom on it. Is it possible to just swap the loom over on the engine as in are all the connectors the same??
message cully or ruan, they will know
/Toseland
1 plug engine loom has extra body loom plugs the 3 plug engine ecu loom dosent have
GTI6 Info
I'm going the other way - single plug to 3 plug!
just swap the loom plus any sensors that are different.
I've got a single plug ecu if it's any good to you bash?
(25-02-2017, 03:54 PM)welshpug Wrote: just swap the loom plus any sensors that are different.
Yeah this is my only thought. I just want to know fuel pump and major bits are bot diffrent. I have my old broken hdi engine with its loom to go back in. But ive found a three plug setup i was gonna assume it was ok to be honest
  any tips for removing ecu plug pins madmadmax 2 1,562 08-11-2017, 11:02 PM
Last Post: Uberderv
  Could incorrect glow plug lengths cause rough idle? JTaylor2005 7 1,915 26-12-2016, 12:24 AM
Last Post: JTaylor2005
  Glow plug fault code? JTaylor2005 2 1,292 22-05-2016, 12:22 PM
