Welding
Welding
Well, my 6 is now garaged, and I've been doing work to it over the last few months, now I have found that the previous owner has jacked it up at the wrong point, and there is now a small hole and rust on that patch.
Does anyone know how much it would roughly cost to fix?
Will
depends where that point is and how extensive the repair needs to be.
(27-02-2017, 11:41 AM)welshpug Wrote: depends where that point is and how extensive the repair needs to be.
Hi, thanks for the reply. I would say the hole is about an inch across? Everything else around it is still solid.
and where is said hole?!
(27-02-2017, 01:01 PM)welshpug Wrote: and where is said hole?!
The hole is underneath the ramp pad in this pic.
Attached Files Thumbnail(s)
Looks like you've got problems on the chassis rail there as well, might be worth having a better check over if you're bothered about rust. Is the hole on the sill or in the floorpan? Is it on a curve, in a corner or on the flat?
It's only on the floor pan on the flat, nothing else's around it, apart from the rail.
  welding pug306driver 1 2,351 26-01-2021, 06:34 AM
Last Post: Mighty306
  Plastic welding bumper? Respraying rub strip(s) Parksy87 7 3,069 29-09-2013, 11:33 PM
Last Post: 306newbie
