Guide: Centre console facia removal
well im fairly sure most of you know but for those who dont and those coming from google here is a quick guide
just a quick overview, ill cover removing air vents and removing fan control panel
Tools
Flathead scredriver
T20 Torx
8mm spanner (or small ratchet)
firstly start of by getting the flathead in between the trim and pull away, this bit is only clipped in so should just pop out
[attachment=12]
next off, if you have the origional HU then use the reccomended way of getting it out or if you have an aftermarket HU like me then prize the trim out then pull the HU out making sure not to pull on the wires too much or damage the HU
[attachment=11]
behind htere youll usually find 2 speed clips, simply push the tabs and theyll pop out
i didnt get any pics of the next bit because quite simply they weren't there when i removed it but if you put your hand through the hole where the HU used to be there will be 2 8mm nuts either side
if you get your hand in there to undo them, its a little fiddly
[attachment=10]
going back to the bottom of the facia undo the torx screws either side of the clock
[attachment=9]
then undo the 2 that hold the clock in...
[attachment=8]
pull the clock out and unplug the clock like so...
[attachment=7]
now you can pull the most part of the facia off, its got some locators that attach into the fan controls so may be a little stiff
going up to the top, looking under the top vents there are 3 more torx located here...
the driver is on the middle one, there is one to the left and the right hand one had already been removed
[attachment=6]
using the flathead screwdriver you can now carefully prize the drivers vent off
this has always been a bit of a tricky bit trying not to chip it or break it so go carefull and use other flatheads as well
you should end up with something along these lines...
[attachment=5]
ive tried to get a good look at the tabs that hold the vent to the facia here, they hook over so unclip these as you go
[attachment=4]
then you should be left with something like this!
[attachment=3]
to remove the fan control panel its a simple 4 more torx
found in each corner
[attachment=2]
next comes the tricky bit, i decided to unclip the wires underneath(green and yellow ones here)
[attachment=1]
and rotate it to bring it out from where the facia used to be to get to the electrical connection on the back
you need to pull up a black tab in the middle of the plug then wiggle it out
like so..
[attachment=0]
et viola! one facia removed!
Attached Files Thumbnail(s)
Thanks given by: mduarte
what about the nuts on the stud bolts to the left and right of the radio?
cully Wrote:what about the nuts on the stud bolts to the left and right of the radio?
shh! lol mine didnt have any which is why i forgot, i know the ones your on about though the 8mm ones behind, shall edit accordingly :S
Cool guide!
Can I add, a safer way to remove the lower part (around the ciggy lighter) is to remove the actual lighter, and pull it from in there. Avoids scratching up with screwdrivers....
And if you do scratch it buy some vinyl and end up with this Smile
[Image: 30e60071.jpg]
[Image: J5hxCcC.jpg]
Looks pretty cool that cj, think I'd end up with a loada creases if I tried though!
[Image: 20120704_212316.jpg]
You forgot to add that your almost guaranteed to break something / find something broken.
On the 306 waiting list.
Toxic-Jake Wrote:You forgot to add that your almost guaranteed to break something / find something broken.
well thats a given it being french... Tongue
Cheers Ben have vents and top glovey done too Smile easy if you take your time
if you break it Plastic weld and wrap haha
Just bought some bulbs and need the replace the heater ones, i will have a go!
This guide will help me a lot, I need to replace some bulbs!
Thank you! Smile
  GUIDE: Gear Knob Removal Eeyore 21 13,724 12-04-2018, 05:02 PM
Last Post: Magenta Sunset
  Guide: Front and Rear seat removal ginge191 15 13,703 09-05-2013, 10:16 PM
Last Post: ginge191
  GUIDE: Steering Wheel Removal/Fitting (including airbags & bosses) Eeyore 3 9,460 11-01-2013, 10:50 PM
Last Post: ozonehostile
