Daves Compound Twin turbo XUD
So managed to secure my actual name so win there Wink Ha11 previously
I wont go into the history of my blue car, as I guess its irrelevant because I now have the black pig...
[Image: IMAG0958.jpg]
It was a bit of a state then....... and its still a state, but I tend to put my efforts into engine power...
[Image: IMAG1289.jpg]
Abit of fettling, and its annual wash and its looking a little better Smile
Swapped all my bits over from the blue car, basically bigger snail, beefy pump, and was running 45psi.
[Image: IMAG1207.jpg]
[Image: IMAG1239.jpg]
[Image: IMAG1392.jpg]
This didnt last too long like that..... as expected... but DHY, it had to go... in style...
[Image: IMAG1380.jpg]
Another DHY rod from the same block... clearly bent
[Image: IMAG1406.jpg]
So got another block in soon enough:
[Image: IMAG1383.jpg]
Then not much happened for ages... car was reliable on a D8A block, with silly revs and ~30psi boost. Did over 10k miles like that...
Then I pulled it apart... and did this...
[Image: IMAG2388.jpg]
[Image: IMAG2507.jpg]
[Image: IMAG2509.jpg]
Wink
[Image: IMAG2543.jpg]
[Image: IMAG2553.jpg]
[Image: IMAG2561.jpg]
[Image: IMAG2522.jpg]
[Image: IMAG2556.jpg]
[Image: IMAG2557.jpg]
Really like this project, full of XUD style win!
HDi Cabby Project Click
alright dave, was thinking how long it would be untill you came on here, turbo looks huge on that lol.
Loving this them pistons look epic.
Team Doesn't own a 306
Looks good nice. Nice pistons Smile
Dave Wrote:[Image: IMAG1207.jpg]
This photo still makes me laugh every time. Glad to see you made it over here.
Dave Wrote:[Image: IMAG2556.jpg]
Big. O_O
PH1 306 XUD - 11mm VE, Big 'bine, TMIC = Plenty of coal, abuse, heatsoak and a power band of 4.3k - 6k = One shagged car.
[Image: sig2.png]
Love the welded rods..proper XUD style!
Dave you never fail to impress me with problem soloutions, the rods are just inspired mate, and also +1 on the lols with the turbo pic!
still sounding like a train at idle when cold I take it?
Team Orange Engine Bay
haha cheers mark, nah not sounding like that now, still running plenty of advance clatter which I looove, but the timing with completely out at fcs.. was advanced probably 10 degrees at FCS... its no where near that now...
hm thought better update this, after the recent tragic fail of biblical proportions that engine got chucked, and the next engine is pretty much scrap aswell, which is pretty shite. Photos anywho.
fubar block coming out,
[Image: IMAG2713.jpg]
[Image: IMAG2711-1.jpg]
car looking very sorry,
[Image: IMAG2761.jpg]
old block.
[Image: IMAG2748.jpg]
turbo had to come apart to check for damage, was ok though.
[Image: IMAG2743.jpg]
[Image: IMAG2735.jpg]
my dad chopping up a scrap crank so, gonna be doing some weight tests and stuff on a piece of material.
[Image: IMAG2763-1.jpg]
Thought was about time I made a visit to the scrap yard aswell, still have half a trailer full of old gearboxes and puch maxi parts....
[Image: IMAG2764.jpg]
And to my disappointment, the worn out donor block, must have done some insane miles, tons of piston slap, and bores glazed to f*ck, which I cant be arsed to do anything with, not worth reworking internals or wasting a gasket/oil.
[Image: IMAG2751.jpg]
and the workspace.... Smile
[Image: IMAG2706.jpg]
Have dropped a totally stock block back in her now Sad so have to just watch boost until I can get hold of a good bottom end to play with again... I missed boost Smile going down to see Darren Ruan and James in next few days unfortunatly its not going to be running anywhere near what I wanted it to be Sad
That's a shame mate. Hopefully the new block will be a bit more reliable for you when you start putting silly boost through it!
Dave has arrived in cornwall, with 4 wheels still attached to the car (just) and 4 conrods still in the block (thank fook) Smile
9mm pump FTL tho!
In te lobbsop at te moment on a totally fail laptop, guess wic keys dont work on tis.... need to swap rear drums...
[Image: IMAG0334.jpg]
[Image: IMAG0335.jpg]
[Image: IMAG0346.jpg]
Im not the best welder,
should flow well though
Looks like a nice project. What power you aiming for?
[Image: Foxy2.jpg]
Fu..kin.....'ell...... Confusedhock:
Nice welding dave.......... :think:
Dan you sarcastic bastard Wink
lol at the welding, that looks like about my standard of welding does that mate, if its functional then who gives a shite what it looks like.............. Big Grin
Its actually alot better than it looks, its penetrated very well to the right thickness its just there is so many gaps that needed filling I just sprayed it everywhere in the end :p I have the other side of the turbo to do now..... turbo to exhaust.... and gear linkages are all in the way, leaving about 1.8inches of room to squeeze enough flow for 6k in there :p
Hello ha11 Wink
[Image: siggy1.jpg]
Hello.... Smile
[Image: IMAG0380.jpg]
Spent this evening making turbo flange plat up etc, the turbo sits so much lower then stock, and I want it to remain OEM fitting so I have to move the exhaust downpipe back up again... bit tight against the gearlinkage as said before but shouldn't cause any issues... if I do find any out comes the grinder... my face is f*cking sunburnt to shit now...
Looking good! :-)
Dave Wrote:[Image: IMAG0380.jpg]
Now that's some nice tidy welding, good effort Dave
Looks like a T25 of a S13?
That inferior technology is coming off... Wink
silverzx Wrote:Looks like a T25 of a S13?
It was bigger than that to start with! lol
From your above comment Dave would I be correct in guessing VNT?
Its got a T28 on it at the moment, as you guessed correctly at FCS Wink
VNT's are £££, control sucks and cruising is shit ... here is the biggest problem I have right now,
[Image: IMAG0360.jpg]
so in two minds to just cut all the linkages and shorten them, have made up a plate as you saw above, but its a little narrow inside.... EMP/EGT guage post turbo to see how it affects the backpressure I think.... The T28 still had alot more to give with anyway.
The the top part of it right down around dave, on the linkages I mean...will work just the same and be out the way Smile Ive had to do that a few times to fit blowers in!
In chesterfield at the weekend, exhaust fell off, and was on 90% derv... sounded good Big Grin
Video does no justice but still...
http://s585.photobucket.com/albums/ss29 ... EO0393.mp4
  darrenjlobb's Adaptronic Managed Compound Blown Derv Bus Build darrenjlobb 559 433,127 21-01-2022, 08:58 PM
Last Post: darrenjlobb
  XSI Twin Turbo PugLee 89 68,595 04-10-2018, 08:12 PM
Last Post: PugLee
Thumbs Up (SHOW TIME )project number 3 twin turbo ( SHOW TIME ) pioneer DJ paddy 77 60,737 28-07-2017, 08:53 PM
Last Post: pioneer DJ paddy
