306 hdi Central locking driver door
Rainbow
The central locking stopped working on the driver front door. It started to play up abit using the remote. But if I lock the door with the key its fine. I can then use the central locking remote for the other doors then to.
So I take it the central locking motor gone or stuck or sumat?
The central locking motor is that part of the lock catch or separate?
Also are all the 306 models the same or need a ph3 3d or 5d one?
306 hdi 5d
thanks
The door loom in between the A pillar and drivers door Pete.....common fault and I bet you there's a damaged wire (or two).
Peel the rubber boot back off the connector and have a look........
  Central locking/deadlocking/immobiliser going beserk. pug306driver 5 5,931 29-01-2022, 09:29 PM
Last Post: pug306driver
  central locking bypass auto unlocking andyw 1 3,538 04-07-2021, 03:58 PM
Last Post: Mighty306
  Universal remote central locking carrot 1 4,047 19-02-2021, 07:58 AM
