Amp cable
I'm running my amp cable underneath the car next week is a piece of garden hose suitable as protection for the power cable ???
bodgetacular, but would probably work.
fyi, cable armour is like a fiver from screwfix for more than enough
Is it ill try there website now then cheers mate
think so, something around that price anyway
Is this the stuff
http://m.screwfix.com/p/tower-corrugated...-10m/50443
yep that'll do the trick mate
Hang on.
It takes around 45 minutes to safely run the cable through the car interior to the boot. Why are you running cable underneath the car?
[Image: Sig500x130.png]
Cool cheers mate
still easy enough to run it under the car Chris, and if it's in armour and help up so it's not gunna get snagged on anything, I don't see any issue?
(15-01-2013, 04:32 PM)C.A.R. Wrote: Hang on.
Because I can't see anyway to get the cable through the bulk head
I have air con on mine if that makes a difference
Use the same grommit the aircon uses then for the condenser
Where's that ?
Tbh it'll be fine without aslong as its not going to chaff on anything. I am running my battery cable under the car just tie it up to the brakelines ot the way
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Or just run it under the car. Just as safe and easier.
I just drilled through the car on the left of the air con grommet on my past 2 cars. On the estate ive gone through the grommet on the top rght of hte master cylinder!
I'll have a look at it in the morning if the weather is dry
Is there anywhere that's guaranteed to get it into the car fairly easily
tbh mate, easiest way is thru a grommet in the boot floor, save f*cking about in the engine bay with limited space etc
Just don't do what my mate did and have it wrapped round the exhaust
Round the exhaust that's not a clever idea
When I swap the headunit I don't need to swap any cables over do I on my old vw golf I had to swap the red and yellow wires over so that it would remember the stations and positions on cd etc
(16-01-2013, 12:23 PM)Sambarker Wrote: Just don't do what my mate did and have it wrapped round the exhaust
what a massive fail! lol
my amp cable runs under the car, i sleaved the cable in plastic air line then cable tied it to the brake lines
just be carefull going under the bulkhead near the chasis leg, the antiroll bar is a moving part and may rub through the cable
