15-01-2013, 11:48 AM
(This post was last modified: 15-01-2013, 02:04 PM by JoshDturbo.)
Hello all
Well my last 306 i broke the silver one, now this so i think thats me done with 306's now.
think you will have all seen this one on here, don't know the problem with it i overtook my mate and then lost revs and they kept on dropping tryed to regain with a lower gear change but no luck then it just cut out and wouldn't start sounds like no compression there and the amount of black smoke was ridiculous.
Anyway here's the spec and pictures.
Lowered all round
Rear lowered 90mm
Front Lowered 100 sits well
All rear windows tinted
Crystal headlights
Half leather interior, a/c, electric windows.
Sub zero ice cd player with sony xplod 6b9's in parcel shelf.
Has had a new engine in only done 90000 miles (BROKE)
Has Front mount intercooler with 2 2.5 inch pipes
Xantia inlet
has been gov modded and grounded lda pin.
Oil catch tank
Garrett m27/t28 turbo running 19psi picture before it was fitted uploaded.
9MM Bosch pump (can be run on oil if you want but i have never run it on it smells like fish and chip shop on wheels if you do but alot cheaper to run!)
Dump valve
Slimline fans on switch inside car
Boost gauge in a pob in air vent on driver side.
Laguna splitter
Straight through pipe to a cherrybomb exhaust sounds mean!
I had new disks and pads put on the front soon as i bought it because the brakes were dreadful.
Have had 2 tyres put on the front about a month ago, back tyres are in good condition.
There is a project page on 306oc http://306oc.co.uk/forum/thread-495.html
Which you can see all the work done.
THERE IS 5 MONTHS TAX OFF IT BUT DEPENDING ON PRICE I GET FOR IT I MIGHT CLAIM IT BACK.
MOT till may next year.
Needs a new power steering pipe as this has somehow broke in half i bodged it up an put fluid in to see if the pump was still working which it is so defiantly just needs a pipe but didn't bother me one of them oh ill get it done on the weekend but then forget.
Now you could simply fix this as it could be something or nothing i don't have a clue though? or have it for parts.
Lowered all round
Rear lowered 90mm
Crystal headlights
Xantia inlet
Oil catch tank
Dump valve
Laguna splitter
