Light wiring diagram question - please help!
Here are two photos of the driver's side and passenger's side rear light wiring harnesses:
[Image: ColorTouch.jpg]
[Image: ColorTouch-1.jpg]
I have a 2001 (Phase 3) HDi.
I have a couple of questions about attaching a 7-pin lightboard socket to this circuit. I am using a Maypole MP843 kit, which uses scothloks to connect its cables to the vehicle's existing wiring harness.
1. Is it correct to assume that the kit should be hooked-up to the driver's side light cables? Am I also right in thinking that the passenger's side lights are fed from the driver's side harness (with the insulated cable running out of the bottom right-hand corner of the top photo above)?
2, Which cables are which?
I ask, because the rear lighting diagram posted here completely confuses me and I see no correlation between the actual cable which I have photographed and the diagram itself.
I need to be able to identify the following:
  1. R/H indicator
  2. L/H indicator
  3. R/H tail lamp
  4. L/H tail lamp
  5. Stop lamps
  6. Rear fog lamps
I would be really grateful for some clarification please. Thanks in advance.
Cant you get a multi meter and probe that plug you've pictured whilst getting someone else to operate the lights? Hey presto your all sorted Smile
pinout plug for a ph3 hatch
Drivers side light unit
plug pin number
1. - Brake light
2. - R/H indicator
3. - Ground
4. - Reverse Light
5. - Fog light
6.
7. - R/H tail lamp
Passenger side light unit
plug pin number
1. - L/H tail lamp
2.
3. - Fog light
4. - Reverse Light
5. - Ground
6. - L/H indicator
7. - Brake light
Rep Please
Thank you! I will test that out tonight and then give you mad reps! Smile
May ask why?
(15-01-2013, 10:06 AM)Just Sean Wrote: May ask why?
I would guess for a trailer, or like the link suggests, for a bike rack that might otherwise obscure the rear lights Smile
[Image: Sig500x130.png]
this is a ph1-ph3 rear light conversion diagram but should help you work out which wire does what. hope this helps
  Wiring diagram for heated seats bebic 0 2,973 28-04-2019, 07:30 PM
Last Post: bebic
  3 Plug ECU wiring diagram Uberderv 2 5,639 09-07-2017, 01:04 PM
Last Post: Uberderv
  D turbo ph2 fuse box diagram hilly5672 1 2,890 23-05-2016, 10:15 PM
Last Post: hilly5672
