Steelies for 306?
Has anyone fitted steelies to their 306?
Fancy the idea of a set of painted 17's sort of like the old 205 rallye's but not sure how they'll look. Or if you can even get 17" steelies to fit a 306..
Any help would be great
Dont think you will find 4 stud 17" steelies
Dumdum is running 16" steels
Think you'd be hard pushed to find 17" steels with 4x108
^^^^is that not what I said?!
Yeah, posted on my phone, slow posting, cbf to edit
Thanks guys. I'll have a look at dumdum's
Smile
7.5x17" steels in 4x108 are available new from Peugeot, although they arent cheap.
[Image: sig.jpg]
(13-01-2013, 05:36 PM)Rod1TDi Wrote: Thanks guys. I'll have a look at dumdum's
Smile
My car is awesome, 16x6.5" berlingo steels and i paid £60 for a brand new (but second hand) set from a bloke who converts berlingos to have a rear mounted wheelchair ramp.
They are ET26 as standard so youd probably want spacers and new bolts and that will cost more than the wheels. Ive got 10mm spacers at the front and 15mm spacers on the rear and im running 205/50R16 tryes. toy keep the spedo correct they should of been 205/45R16 but i like the more comfy ride.
(13-01-2013, 05:49 PM)Chris Wrote: 7.5x17" steels in 4x108 are available new from Peugeot, although they arent cheap.
IIRC off the 3008 (look in service box and you will ifnd)
I do beleive so Chirs.
If they are they'll be ET29
5401W1 53.98 each
[Image: sig.jpg]
Also (as a plan b) how much does a decent set of gti6 cyclones go for now days?
Arnt the 4x108 17 7.5J's from the 308/ some citroens? maybe worth trying a breakers or somthing?
(16-01-2013, 07:40 PM)puglove Wrote: Arnt the 4x108 17 7.5J's from the 308/ some citroens? maybe worth trying a breakers or somthing?
think you might have issuse with that size. all depends on how low the arse end is.
ive got about 75mm on the back running 16 inch, 7.5j with 195/50/16 on and with just me in the car over bad bumps it scrubs. get 3 in my motor and have to get him /her to sit in ths middle so wouldnt 17's be worse?
Na iv ran 17inch 215's on a 306 without issue, I'll fech a pic just for lol'z
  All there is to know about banded steelies W1ll 11 6,813 28-04-2013, 03:17 PM
Last Post: Birk
