Turbo oil feed thread size
Anyone know the thread size of the block for having an oil feed made Think its M14 or M16 but i have no idea of the pitch.
Just gonna get an AN4 or AN6 line and adapters.
M16 x 1.5 iirc
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Piggy has just measured one for me and its M16x1.5 on the 2.1TD
Hes got a pic of it next to a pug wheel bolt (M12x1.25) and the thread pitch is definitely coarser but not by alot so im gonna suggest that its right.
piggy Wrote:the thread gap appears to be 1mm by the gauge...
[Image: 20130113_132645.jpg]
[Image: 20130113_132706.jpg]
certainly not a 306 bolt thread
[Image: 20130113_132901.jpg]
and not tapered
and it aint same pitch as a M6 or any bolts I could find in me bolt drawer!
hope this helps too
[Image: 20130113_132509.jpg]
The low pressure side...
[Image: 20130113_132552.jpg]
hope that helps?! That piece pushes into the block...can be seen in photo.
Don't know if this is any help to you at all but if you have any power steering pipes lying about, the bolt is the exact size for the block. Well 205 one's are anyways.
Stage 2 XUD Sedan
(13-01-2013, 06:09 PM)strictly_derv Wrote: Don't know if this is any help to you at all but if you have any power steering pipes lying about, the bolt is the exact size for the block. Well 205 one's are anyways.
Same on 306 also Smile
Erm, I dont think so, I do have an electric PAS pump though
  turbo relocation pipe size Chris_90 10 6,906 08-08-2015, 12:32 AM
Last Post: Paul Baldwin
  Twin turbo high pressure oil feed setup. 205dtub 17 8,349 23-02-2015, 07:47 PM
Last Post: 205dtub
  What thread is fuel feed for a bosch? silverzx 8 4,966 04-02-2015, 03:51 PM
Last Post: silverzx
