How does a MBC work with a KKK?
Thanks.
Thanks.
KKK MBC Question..
Thanks.
12-01-2013, 01:22 PM
I think its the t2 and gt15 that share the same manifold
The kkk has a different smaller one so I don't think it will
12-01-2013, 01:30 PM
Damn.. Would the KKK and newer K03 share the same manifold?
12-01-2013, 01:32 PM
It'll be fine, K14 and T2 are interchangeable and share same exhaust manifold
Exhaust elbows off both turbos line up with exhaust no problem, oil lines should be the same too.
16-01-2013, 01:46 PM
and does anyone know how a MBC works with the K14? What do you connect it to :/
16-01-2013, 02:24 PM
Theres a little metal pipe that comes of blower housing you have to cut this halfway and then put MBC inbetween with silicone hose and zip ties well thats what i did didnt make much difference my advice would be wind the fucker right in and run big boost lol
16-01-2013, 02:31 PM
(16-01-2013, 02:24 PM)CJ_Derv Wrote: Theres a little metal pipe that comes of blower housing you have to cut this halfway and then put MBC inbetween with silicone hose and zip ties well thats what i did didnt make much difference my advice would be wind the fucker right in and run big boost lol Did that on the last one mate, with a good bit of fuel and there was no impellor left in the hot side lol. You have pm by the way mate.
20-01-2013, 05:39 PM
OK so i got a KKK "K03", but the high pressure hose isnt really lining up, it was off a 406 kkk turbo :/ dont ask...
Does the high pressure oil line off the K14's and t2's fit the K03? |
