How have you fixed your relocated battery
What do people use for this? I was wanting to use a fibreglass or metal tray to mount into the bootfloor so to use aslittle space in the boot but has anyone else done this?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
I just bent some flat bar to hold it to the boot floor in Dimma.
[Image: 704e7db1.jpg]
Great big self tapper straight through the middle, it'll be fine. Honest.
Hmm i would prefer it enclosed tbh, Dan was that in the boot or under the car?
Anyway Phil! Where is my slightly bent bar???
Blaze 1.6 Dead
I enclosed mine in a box mate...
That's what I am doing but want it sunk tho the bootfloor. Would fibreglass be strong enuff to support a battery?
Blaze 1.6 Dead
Iam using a sealed marine battery box can get em on eBay
[Image: SDC10442-1.jpg]
(09-01-2013, 05:53 PM)HDIkyle Wrote: That's what I am doing but want it sunk tho the bootfloor. Would fibreglass be strong enuff to support a battery?
I would get something welded personally. Then its metal to metal. Not sure how you would wrk fibreglass to metal.
(09-01-2013, 06:33 PM)SRowell Wrote: I would get something welded personally. Then its metal to metal. Not sure how you would wrk fibreglass to metal.
with some bolts....
Pop rivets and some sikiflex to seal it I was thinking
Blaze 1.6 Dead
Just sat in the boot mate, I want to sink it in the floor, but couldn't be arsed to find a box lol
Just bond a fibreglass box in, if you use a decent polyurethane or epoxy adhesive you'll be able to jack the car on it....
cant your use a original box fromt the engine bay with the lid ant the metal bottom plate and bolt it to the boot floor?
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
I've got a box welded into the bootfloor, all painted and sealed. Really looks a lot better than just having a box on the boot somewhere
(09-01-2013, 09:31 PM)ozonehostile Wrote: I've got a box welded into the bootfloor, all painted and sealed. Really looks a lot better than just having a box on the boot somewhere
That's what Iam going to do when we corner weight it!
Ill just use a fibreglass race box can get em for 30 on ebay and some sealant we use for bonding train windows in. Karl mine is just a metal tray I gut out as the bolts rusted didn't even hold the battery it just sat on it kinda
Blaze 1.6 Dead
Anyone got pics of it sunk in to the boot?
not a particulerly great picture, but you get the idea
[Image: IMAG04331.jpg]
You should have a vent on that really, otherwise the fumes can start to attack the steel if they build up when it's charging. They're particularly nice for your lungs either....
theres no top on the battery box so i figured it would be ok. am i wrong?
should really be vented externally, would prefer top sealed and a couple holes outside underneath if it were me..
i think i might have to do that then. just didnt want the box filling up with water
Yeah, you want to vent the fumes outside the car really.
Iam going to vent mine with a couple of tubes out the top into the rear sunroof drain holes, with a sealed marine box
at least for me a vent should be easy, just need to run a tube from the box to the wheelarch or something
  Fixed please delete Leemus 11 7,479 18-05-2017, 08:01 PM
Last Post: Leemus
  Flat battery/ can't open at to charge battery Aaron _d95 18 15,831 01-12-2013, 08:26 PM
Last Post: C2K
