Fuel pump question
Fuel pump question
Screwed my bosch pump last week, gave it half a turn and it made a good bit of difference but there was very little smoke out of it so i gave it another half turn and it is going good now, also gave the boost compensator 1.5 turns. My last 306 had a lucas pump screwed half a turn and it was twice as smokey as my 306 is now, is this normal? is the lucas max fuel screw different to the bosch?
ideally you want as little smoke as possible on boost, after turning up the fuel on a bosch you should wind out the lda pin to reduce off boost smoke, winding it out means more fuel on boost so you can make significant gains without it been stupidly smokey
Its because the Lucas is shit, basically.
^^^yeah, and that lol
  Bosch pump fuel screw broken Forby 0 2,735 12-03-2019, 06:47 PM
Last Post: Forby
  Cold start issue- fuel pump? Blaze Addict 3 3,292 20-01-2019, 11:10 AM
Last Post: Martin306
  Is immobiliser coded to fuel pump? Huddo 2 2,855 07-12-2018, 03:04 PM
Last Post: Ruan
