Advice and Input Needed :)
Smile
As some of you may have read in my other thread
http://306oc.co.uk/forum/thread-9215.html
I have decided to take the engine out and replace the engine loom and tidy up the engine aswell as sort out the oil leak i have at the back of the engine which i suspect to be turbo related so my question is
What would you recommend to do while the engine is out
I'm thinking so far a good clean so its spotless!
Replace the gaskets possibly including head gasket.
Make sure my timing is correct.
Also what other bits and pieces do you reckon i'll need.
I'm sorted parts wise as working for ECP has its benefits Wink
Any advice will be good
James
[Image: ForumSignature.jpg]
lap in the valves and replace valve stem seals
cambelt, waterpump, tensioners
check all your rack boots and ARB bushes...soooo much easier when no engine!
if i was in that position id replace everything i could afford. and possibly balance it
Remove the EGR system. It's a lot easier to do with the engine out.
Total overhaul of all serviceables - belts, fluids, filters, glowies (don't forget the ones in the pre-heating circuit), etc - unless your cambelt was done 10k ago or something. Doing the egr is a good shout too. Check your rubber piping for signs of deterioration.
Also clean up your engine bay, particularly any earth points. These cars are getting to the age now where corrosion is starting to make an appearance, best to nip it in the bud with a clean up and a fresh coat of paint. Got broken aircon? If so sack that off too.
  306 HDI not starting, advice needed, fuel? sam-b 2 998 12-02-2014, 05:26 PM
Last Post: sam-b
  Gearbox input shaft bearing on the way out? JonT 7 2,633 14-10-2013, 06:55 PM
Last Post: JonT
  Turbo. Advice needed! Jonny81191 9 2,781 16-05-2012, 04:33 PM
Last Post: Jonny81191
