20-12-2012, 09:44 PM
Does anyone happen to know the thread size for the block off the top of their head? I'm trying to get a line sorted for the new blower.
Thanks
Thanks
Stage 2 XUD Sedan
XUD oil feed block thread size
Thanks
Stage 2 XUD Sedan
20-12-2012, 09:45 PM
(This post was last modified: 20-12-2012, 09:47 PM by zx_volcane.)
yup one sec...
m16 x1.5, i put n my project thread as I knew I'd want to know again
21-12-2012, 06:33 PM
Be warned though, the length is odd... Best way is to use a T2 line with a compression fitting half way... Or find a banjo bolt out of a HDi as the length is the same
22-12-2012, 09:00 AM
Any banjo bolt will work using the right thread as the banjo only relies on the copper washers not the seat at the bottom, but that will work just fine
| #DervMafia | ![]()
22-12-2012, 10:06 AM
I can sort a braided line to any spec you want
| What thread is fuel feed for a bosch? | silverzx | 8 | 5,526 |
04-02-2015, 03:51 PM Last Post: silverzx |
| temperature sensor thread size | Chris_90 | 2 | 2,474 |
22-09-2014, 04:35 PM Last Post: Chris_90 |
| GT2052V & TD04 Oil Feed Thread | silverzx | 7 | 6,073 |
18-07-2014, 05:02 PM Last Post: Tom |
