BREAKING forged engined black d turbo
This is only to see what interest id get if I was to break it full spec is in my project thread but here a quick list
fully rebuilt bottom end with forge d rods and fully balanced had new shels piston rings the lot only covered 73 miles before the head let go twice open to offers on this. £ DEPOSIT TAKEN Smile
Cg 5 paddle sprung clutch same miles as engine £sold
Hdi gear box all new genuine pug seals sold
Tdo4 ready to go will come with a stainless down pipe £210
11mm Bosch all the usual mods inc lines and injectors was resealed with genuine bosch seal when built sold
Fmic inc manifold and slimline fans£sold
brand new devils own meth kit never used £200
battey relocation kit to the boot inc a bosch 5 year garuntee battury £80
half cage ? sold
race tech ipp gauge and pump take of with out need to dill the pump body only fitted for few miles||£sold
hks egt gauge £50
boost gauge £sold
also got water temp volt oil temp and oil pressure£sold
gti 6 rear axle inc calipers discs and pads almost new £sold
gti6 front brake set up inc master cylinder and good discs and pads £65
mocal oil cooler kit one done a few miles with braded hoses and thermostatic plate £sold
rips lower brace £sold
e tech top brace fits over tmic £sold
ta tech coilovers had new top bearings a year ago £sold
steering wheel and boss £sold
stainless cat back exhaust £sold
set of morettes new outer lights and inners removed and replaced with trumpets new inecaters £sold
tinted rear side windows £sold
new upraed gear links £sold
ph3 spoiler £20
side skirts |£15
braded front brake lines only been on car since may still good con £5
powreflex bottom engine mount|sold
standard seat bases modified to fit bucket seats i had cobras fitted i assume there all the same bolt hole? £sold
gti splitter £sold
gti boot trim £sold
ph3 side strips£20
manual boost controller £10
metal monkey speedo background and heaters £sold
smooth boot needs smoothing again as cracked but comes with boot popper £sold
body panels offers
fully reconed cylinder head precups droped so needs over sized ones fitted offers
new recon cylinder head 3 new valves all new seals and so on only done aprox two hours running £150
smoked standard rear lights £10
half smoked rear lights £5
gloss black slam panel £10
drive shafts £15 each
there's loads look in my project thread .
all prices plus postage and packing
Any questions please pm me
Have you got pictures of the car and have you got anything else on there?
If you look under ash23s project Lucy there's loads of upgraded parts I'm on my phone currently so can't link you
[Image: 2012-03-18143746.jpg]
[Image: 2012-09-29162021.jpg]
[Image: 2012-11-03080945.jpg]
project thead
http://www.306oc.co.uk/forum/thread-303.html
What size are your intercooler pipes?
there 2.25 mate
Whats the spec on the cage? I.e mounts type & placment
(17-12-2012, 06:38 PM)puglove Wrote: Whats the spec on the cage? I.e mounts type & placment
ii belive its one some one got made it came from cjm harris on the 6 forum not the best but stiffens the car up a hell of a lot
it mounts to the rear seat mounting points and on the floor idealy would need plates welded in to bolt to
Did you ever get a figure with the td04 on?
[Image: 704e7db1.jpg]
(17-12-2012, 07:08 PM)Birk Wrote: Did you ever get a figure with the td04 on?
No engine isn't run in yet so was only running 28psi but even so it was freaking awesome Inlove
I'm interested, but price seems a tad high really.
When did the turbo kick in ?
Is that price posted for the gti6 brakes
I think you've got some pretty good prices there. Possibly interested in the forged rods, don't know how much to offer for them though. Are they dt or hdi?
[Image: 20120704_212316.jpg]
Ash no!! This car is so much win!!! Why would you do it after all that work? Confused
Official Team Go-NAD fan club
What gauges you got?
Is that a ph3 front end on there? If so condition of bonnet and bumper and lights and a a price please
(17-12-2012, 08:35 PM)Birk Wrote: I'm interested, but price seems a tad high really.
Thought it was a good price for a direct bolt on kit and this still uses the actuator and no bulkhead issues
can't remember when it kicked in b3ut I didn't find it bad and i was use to a tiny ko3
[quote='Tyronnster' pid='179500' dateline='1355779827']
[/quo
could do em for that yes
I won't know what is happening with the car for a few weeks cause I going to strip the head of again and see what's its done this time and then decide what's happening.
If I do break the bottom end is already prov sold.
Interested in the engine and maybe the car.
If you have an idea on the price for the engine, and clutch, and rolling shell.
I dont need wings, bonnet, bumper, headlight, bootlid, brakes, suspension or the alloys.
Mark I must say this car is a gorgeous car! Pulls like a train an that was before the new turbo!
Its basically the same spec I am starting on, but with a different turbo.
If I can get it at less than what I have priced up so far then all good.
Gonna have to come up one weekend ash before this goes and go on a little run
(18-12-2012, 06:26 PM)ash23 Wrote: [quote='Birk' pid='179473' dateline='1355776554']
(17-12-2012, 09:30 PM)Tyronnster Wrote: Is that price posted for the gti6 brakes
[/quo
Will leave it as would want them asap
Right I did write a reply to everyone but looks as it didn't work.
basically I won't know for a few weeks weather she will be broken. I'm goin to pull the head off again over the x mas break then go from there..
Mark if I do break her the bottom end is reserved for someone else.and sounds silly but the shell won't be goin anywhere until I scrap it
milkman it was 100% quicker than when I took you out in the old engineSmile but after now what is two new heads its pressuring the coolant again so not sure if this time it was me using a shit gasket in the rush to get it fixed or dropped pre cups again but I will be investigating this Sunday/Monday
Well consiering people run TD04 more and more I've not known any ones head to lift so I'd say gasket or bolts right?
Won't be the head that's lifted was running upgraded head bolts with the first head then that dropped the cups but on rebuild with the second head used stock just to see what happened but its got the exact symptoms as the other head with the shot cups we'll soon see what's gone of and if its the head again a may well just build a super head with different pre cups in but see what happens
or just knock all the cups out and put hdI pistons in and run it di Tongue
Well I will be interested in the boot, Pass door and maybe turbo kit if I don't get one before you strip it.
I'm interested in the paddle cutch and the battery relocation kit dude. Have you got pictures please
Interested in
Fmic inc xantia mani with the egr stuff removed and welded back up£150
if you break it
David no pics still on car but clutch is almost new
Ezb if I break ill give you a p m mate
any more interest if I broke it?
Still waiting for a price on the front end please....
  Xud forged rods Xud Missile 3 11,547 31-01-2022, 09:13 AM
Last Post: Xud Missile
  Breaking: Breaking ph1 d turbo decat ect Danny2009 18 9,994 24-12-2019, 07:56 AM
Last Post: Julian Creal
  Breaking - Black 98 GTi-6 Ben_w 40 23,205 26-09-2017, 07:27 AM
Last Post: Ben_w
