Car feels underpowered so I used the scan gauge to look for faults and I've got a code pending...
FRZD.... ?? anyone know anything??
Also showing p0903...
halp! code pending
FRZD.... ?? anyone know anything?? Also showing p0903...
17-12-2012, 02:13 PM
17-12-2012, 02:14 PM
Have just googled it and it seems like clutch circuit actuator high... Any ideas people?
17-12-2012, 02:16 PM
If I remember correctly frzd can be an early sign of RG failure
17-12-2012, 02:17 PM
Raccoon gasket. Not too bad to change and luckily parts are cheap
17-12-2012, 02:19 PM
I want to b mad but I can't stop laughing!!
17-12-2012, 02:23 PM
(This post was last modified: 17-12-2012, 02:23 PM by Midnightclub.)
P0903 is a red herring i believe sean, emmas HDi had it the other day, after clearing it though it hasn't come back since
EDIT: i can't remember the exact code actually so it is probably the EGR fault code for when you unplugged it
17-12-2012, 02:24 PM
Its only just cone on though...
17-12-2012, 02:27 PM
The code. No eml lights.
17-12-2012, 02:28 PM
Sean, we can have a look tonight at the codes. PP will give a good idea as to what it is
17-12-2012, 02:31 PM
If I make it. Losing interest quick!!!
17-12-2012, 02:33 PM
It's a silent fault code mate so it won't bring on the light, if you get a chance to use PP then that'll be your best shot
17-12-2012, 02:46 PM
But its affecting performance!!
17-12-2012, 02:51 PM
I don't even no what that means sunny!!
17-12-2012, 02:54 PM
MAF = Mass Airflow sensor, it's the one directly next to your airbox with the plug in it.. unplug it, go for a hoon and see if it pulls any better/worse
17-12-2012, 05:01 PM
Even if the car feels like it doesn't have a stage 1 map? Like no pull what so ever?
17-12-2012, 05:06 PM
(This post was last modified: 17-12-2012, 05:07 PM by Midnightclub.)
If anything that'd be the prime symptom lol! It takes less than 10 seconds to pop the bonnet and unplug it.. if it's the same 5 seconds to plug back in, no harm done
Halp Meeeeeeee!!! | MrsMidnight | 27 | 5,329 |
22-08-2013, 12:31 AM Last Post: Tallguy_2 |
West Midlands Members - Halp. | Kezzieboy | 6 | 3,014 |
09-04-2013, 02:46 PM Last Post: Kezzieboy |
Accidentally OD'd on paracetamol - Halp | Dan! | 43 | 12,748 |
18-12-2012, 03:43 AM Last Post: David |
