306 hdi heater problem
Bug
The heaters on my 306 hdi are not working at the moment.
Ive checked all the fuses inside below the steering wheel and in the engine bay there all fine.
Where the front interior light is the little fan still goes around. Also I can hear the fan motor near the glove box before your start the car. It makes the small noise but thats it.
The speed control makes no diffrence and the hot and cold setting.
So, is there no heat? Or no blow?
(16-12-2012, 01:45 PM)Toms306 Wrote: So, is there no heat? Or no blow?
There was no blower. But I took the heater out then put it back in and it worked. I've cleaned it all up now when I took it out the second time. But it all seems to be working ok now so maybe the connector needed taking on and of or the heater needed moving about or something.
  Heater blower problem Pingaz 7 2,271 04-06-2016, 01:19 PM
Last Post: Pingaz
  heater blower severe problem Harky 1 991 08-09-2014, 11:24 AM
Last Post: vincent1
  heater problem 318d4n 2 1,225 11-05-2013, 08:50 PM
Last Post: 318d4n
