15-12-2012, 10:31 PM
smoothed grill for a ph3
smoothed grill
15-12-2012, 10:34 PM
If you google image: "smooth grill meme", one finds quite funny results.
Captain Standard
15-12-2012, 11:46 PM
Do it yourself pal, really is simple.
Get yourself 1 roll I masking tape 1 fibreglass matting kit (£10 halfords) Some filler Primer Paint Lacquer Mine took about an hour if that! ![]()
16-12-2012, 09:54 AM
did you cut that recess out where badge goes?
16-12-2012, 10:14 AM
I did mine impatiently and stuck abit of wore mesh in the recess and filled over the top with fibreglass it weighs a tonne lol gunna strip it at some point and do it again with a piece of my othe grill
16-12-2012, 02:40 PM
Yeah mate cut it out like so
![]() Rough up the back with the dremel Masking tape over the painted side Turn upside down Fibreglass the shit out of it Rip off masking tape Sand down so all the fibreglass sits lower than the painted surface Fill with filler Sand smooth Primer Paint Lacquer Job done
16-12-2012, 05:37 PM
you got a pic of the back of yours Si?
16-12-2012, 07:08 PM
I can get one next time I'm at my mums.
I intended doing a guide on it but my iphone is shite and keeps dying! ![]()
16-12-2012, 07:20 PM
Coolio! One I've got has just been filled, weighs about 4.73 tons
16-12-2012, 07:29 PM
Lol, don't think you can really tell any difference with mine tbh.
Put a pic up ![]()
needs some more work, i've sprayed a guide coat onto it, it was in primer, but there are a few lumps and bumps
ill get some pics up when i can be arsed lol Member of the 99% warning or you're nothing club
16-12-2012, 07:38 PM
You'll smooth them out easy enough, use a block to make sure you get the angles right and you'll be fine.
16-12-2012, 07:39 PM
yeah that was the plan, doing the exact same thing on the rest of the car
16-12-2012, 07:43 PM
actually really enjoying it! for now anyway, i've only done half the rear quarter with 240 grit lolz
16-12-2012, 07:47 PM
Haha yeah that'll wear off pretty quick!
To be fair I still love doing it but is slow tedious work. ![]()
16-12-2012, 07:48 PM
true that. and i stil have to plug and fill the aerial hole, and the rub strip holes. and then find and smooth a bonnet! my right arm is gunna be HENCH
16-12-2012, 08:03 PM
Bonnets are easy enough, you need to get yourself a small detail sander to get the thickness of it off, makes it a lot easier!
I'd come give you a hand but its a bit of a trek ![]()
16-12-2012, 08:41 PM
Ah noted, I've a cheapy one kicking about!
nonsense, not that far, you drive an hdi! Member of the 99% warning or you're nothing club |
| Wanted: Smoothed bonnet and grill :) | Keeno123 | 0 | 1,405 |
15-08-2013, 08:22 AM Last Post: Keeno123 |
| Wanted: Exhaust, smoothed bonnet and grill | joey306 | 7 | 4,875 |
09-11-2012, 10:13 PM Last Post: Eeyore |
| 306 smoothed grill and bonnet WANTED!!!! | ANTB1986 | 14 | 7,589 |
20-07-2012, 01:20 AM Last Post: bowers |
