Bosch pump advancing
My pug currently has lucas injectors and bosch pump bosch injector are ready to go in with new copper washers and fire seals, the thing is my pump has been advanced quite a bit, so anyone know if its ok to just chuck my bosch injectors in or should i retard the pump back to standard too? If so i will wait until iv got my cam belt kit and do it in one go
Also whats the best way to give them a bit of a clean, leave them soaking in some diesel etc?
Just chuck the Bosch injectors on. It won't cause a problem, although for optimum running you should aim for 3/4 advanced. Petrol is a solvent and therefore cleans injectors well, just buy some petrol and pour it into a pot and drop the injector peices into that.
Cheers now to find a vice so i can crack them open anything i should watch out for?
  Slack in bosch pump? dt_ 14 10,810 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,233 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 2,933 12-03-2019, 06:47 PM
Last Post: Forby
