Window switches buzzing?
Every now and then my drivers side window switch buzzes. When this happens, theres no movement in the windows (both sides) and it doesnt matter what switch I use.
Give it a few minutes and then they work perfectly.
Normally happens in the night if I havent used the car all day, if I use the car throughout the day, it wont happen (much).
Im thinking a dodgey connection somewhere, or possibly even the switch is faulty?
Any ideas?
its the contacts in your door loom big connector corroded had same problem on mine had to put new plug on door side of it
[Image: J5hxCcC.jpg]
They are a little, but all are making good contact with eachother.
I duno then pal, my contacts looked ok bar one and changed it and it worked
That might be it then, I guess changing them will only bring benefits
try lots of wd40 in them first clean contacts a bit see how u go
  Strange buzzing noise. underground375 1 1,850 04-02-2014, 09:56 PM
Last Post: DeeTurbo
  rear window switches hucky 0 1,729 22-11-2013, 03:59 PM
Last Post: hucky
  Why do i keep blowing.. giggedy.. switches ginge191 13 8,604 14-08-2013, 12:05 PM
Last Post: Rich306
