306 Gear linkages, Dec Offer/end of line
This will run till the end of Dec maybe mid Jan as these are now end of line before my new versions come out which are basically adjustable on the car which no one else offers
So all XU engine's and BE gearbox's are all the same fitment, £35.00 delivered (UK Mainland only)
If you need any for TU engine's I should be able to sort as I know or think there's 2 types of which none I have seen
Quick-shifts will follow too but welded to the 'L' so no chance of them coming loose etc
Pic's are here,
http://www.ebay.co.uk/itm/Peugeot-306-GT...3a77aea1d0
along with full item info
how do those compare to these...
www.ebay.co.uk/itm/221152903856?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
No Idea, but it sounds like his description has been copied from mine
I'd go with miles' version every time, he's been making them a lot longer and offers genuine after sales support.
ok....well then how do I pay?
I have been considering some of these may have to invest in a set, as above how would you like the monies Smile
Team Doesn't own a 306
what are the gains from fitting some of these?
(10-12-2012, 01:12 PM)nufc4frosty Wrote: what are the gains from fitting some of these?
Just gives a more solid gear change, not sloppy due to worn rods and balljoints.
Also, these have clips on them so do not pop off
ok thanks for that. so they worth getting?
For that price, yes. Easy to fit too
You probably won't feel any difference in driving the car, but it's piece of mind to know the gear rods won't pop off.
Everything else gets replaced, bushes, track rod ends, etc so why not these. If they wear or break then you have no drive
I posted a thread up abit back asking about the 2 listed as the description was the same but different sellers as iv used miles rods before
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
how to pay??????????????????????
Miles do you sell some for a 205?
Stage 2 XUD Sedan
Please drop me a PM and I can let you have the details, But Card, Bank Transfer or I hate to say Paypal are all good
Yes I cover all the Peugeot Range from the 205 up
Oh yeah, just realised it was you who sold me the linkage bushes on ebay the other week. Will deffinatly look into the linkages. Thanks.
Stage 2 XUD Sedan
Quick Bump, I can do a group buy on these so 10 sets and these would be £30.00 delivered per set
I could be interested in 1 or maybe 2 sets
I'd like a set at that price if someone can confirm they fit an HDi? I would assume they do as the XUD box is a straight swap for the HDi...
Im in for a set on payday (19th)
They'll fit a hdi fine Alex.
[Image: sig.jpg]
Do you by any chance do 106 ones?
Post to southern ireland?
if so how much?
Yes I have 106 ones too, they are slightly more as they are the new design on the shorter rods of having left and right hand threads meaning you can adjust them on the car, the Right handed ones need removing so this GB would be £35.00 delivered
Oversea's postage is £8.50 via Air Sure, Not the cheapest option but it protects both of us if lost
HDI are fine from what I have been told and have sold a few sets for them, but you can always pop down and we can double check
Just drop me a PM for more details please
You still do these miles?
  Cyclones, gear linkages, 406 bottom boost pipe, random boost pipe406 air intake pipe Paul_13 2 3,446 19-06-2016, 10:51 AM
Last Post: Paul_13
  205 bits on offer Magenta Sunset 8 4,971 05-10-2015, 04:53 PM
Last Post: Magenta Sunset
  Uprated gear linkages Chris 4 2,961 25-02-2015, 11:44 PM
Last Post: 306Dan
