Ground Zero Iridium Gzia2235Hpx amp
Am Selling my Ground Zero Iridium GZIA2235HPX i only bought only 1 month ago to power my 12" jbl gt4, was pushing 500rms from it bridged:
Heres the specs:
Ground Zero Iridium Series Amplifiers provide reliable, relentless power by using trusted Ground Zero knowledge and upgraded components for enhancing the audio in a high performance system.
Ground Zero Iridium amplifiers feature tough construction, rugged looks and use sophisticated power supply and output technologies to ensure clean amplification from the input all the way to your speakers.
Features
2 Channel Iridium Series Stereo Amplifier
Bridgeable for Subwoofer Use
High Quality Aluminium Cast Heatsink with Brushed Finish
Easy Fit with Auto Switch-On function in High-Level use
Black High Gloss Plexiglass Cover
White illuminated Ground Zero Logo
Specification
Ground Zero Iridium GZIA 2235HPX
2 Channel Class AB Amplifier
1080W Total Max Output Power
470W Per Channel Max Power
RMS Output Power @ 4 Ohm (CEA*)2 x 150 W
RMS Output Power @ 2 Ohm (CEA*)2 x 235 W
RMS Bridge mode @ 4 Ohm (CEA* / 10% THD) 1 x 540 W
Lowpass Filter 30 - 250 Hz
Highpass Filter 40 - 3000 Hz
Dimensions 28.5 x 21.3 x 5 cm / 11.22" x 8.39" x 1.97"
*The WRMS output power is based on the CEA Standard CEA-2006-A ( 14.4V, 1% THD) tested and approved.
£60
Price is Delivered
Still got this, bargain!
still here, offers
  Wanted: Ground LDA pin? Please :D underground375 4 2,604 22-08-2013, 09:25 PM
Last Post: Dan!
  ground lda Shea 3 2,222 21-03-2013, 02:58 PM
Last Post: Chris_90
  Wanted bosch max fuel screw, ground LDA pin sammy9212 2 2,467 10-03-2013, 12:35 PM
Last Post: dturbopeck
