Threads: 27
Car Model/Spec: Rallye
08-12-2012, 06:46 PM
(This post was last modified: 08-12-2012, 06:47 PM by Jimmyboycheck.)
I'm getting confused with this when I look for something suitable on amazon it doesent mention that it is compatable with a smart tv. Am I looking for the right thing. For example would this work so I can record stuff from my tv
Buffalo DriveStation 1.0TB USB 2.0 External Hard Disk Drive
what tv have you got mate?
Ah ok. Not sure about the sonys but i know all the samsung smart tvs, you can just plug in a hard drive and it will work with the media you have on it providing its in a format the tv can read.
Threads: 16
Any external HDD would work with any Smart TV (capable of recording out to the USB). So yes, the one you "linked" to would work.
Threads: 179
21
Car Model/Spec: Broken Phase 2 GTi6
Given 16 thank(s) in 11 post(s)
only thing i would do to be safe, is to make sure the USB HDD you are using is powered, i.e comes with a seperate power supply. As depending on the TV USB Voltage, it might not be enough to power a self-USB powered disk.
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
Threads: 179
21
probably not record directly to it (again, depends on specific make of TV + Firmware revision)
you would most likely be able to transfer stuff to it though
1. Fooby's Car
1. Learn to Car
