Threads: 61
Car Model/Spec: 306 DT GLX '98
When i start my car up cold, it refuses to start. Revs go to 600rpm and just stay there ticking over. After a few seconds the immobiliser sound goes off.
Then i try again, 600rpm stuck, untill i tap the accelerator it kicks up,
Coughs out smoke for a good 10 minutes and gets really juddery inside.
Only started happening.
Usually starts first attempt instantly!
Threads: 9
Sounds like the timing could have slipped a tooth or you have bad fuel/dirty fuel filter/bad glow plugs. Does it still have all it's power when it's stopped juddering/coughing?
Previous Car: Peugeot 306 XLdt (stock!), 150,000 miles (I miss this car
Car Model/Spec: 306 D Turbo
How does it start when warm? As said could be glow plugs or air getting in
Threads: 61
09-12-2012, 04:59 AM
(This post was last modified: 09-12-2012, 10:24 AM by RePT.)
Starts instantly when warm, has all its power.
dad had a look over, he said its probably plugs or fuel filter..
both of which i will change after my bosch pump.
although I changed my fuel filter 4k miles ago, and ive only ran on derv.
Threads: 36
18
Car Model/Spec: DT
I'd say glow plugs fo' sho'.
On the 306 waiting list.
Threads: 226
24
Car Model/Spec: A3 TDi
What he said^^^
Majority of us on here probably run wank when cold first thing... Its an old diesel thing! Unless you have spanking new plugs and perfectly setup pump :p
Threads: 198
135
Mine starts first time on pure veg, which is weird as i don't have a clue what i'm doing with these engines half the time.
It does have a new 640CCA battery and nearly new glow plugs from Ash23's old head though, but yeah still starts first time on pure veg even when the windows are frosted up.
Threads: 226
24
Im yet to have it not start on veg all ways goes first crank.... But that doesnt mean it enjoys it.... I usually go out and start it then come in and finish me cuppa then leave for work haha
what like pigs dont leave their cars unattended running???
Threads: 226
24
Probably just finding something to moan at :/
Threads: 61
Lol, first encounter with police ^_^,
