11mm Fuel pump / 9mm pump
In urgent need of some cash so considering selling my 11mm fuel pump as i can always do it again one day.
Fuel pump is a typical xud bosch pump which was removed from my car in good working order it has the bosch 414 11mm head from a landrover discovery. The pump was converted by myself and resealed using genuine bosch reseal kit. since the rebuild the pump hasnt been on a working car just sat in storage in oil. The pump was made using various guides off the net and everything is timed right. Pump will be gov modded also but standard LDA and not tuned. This will be down to you. this is just the pump only. Will need a throttle cable bracket but can be made quite easily.
Looking for what it cost me to do which £110 some may think its a bit high but this is what it cost me. Can help fit tune etc if local.
or if some one is after a 9mm pump the one currently on my car is in full working order currently powering a 173bhp xud with no issue. This is gov modded and tuned out of the box. I will not include the Lda this would be standard one. And you will have to wait for it to swopped over.
looking for £50 pump only
which ever sells first will be the only one sold the other will still remain
www.prestige-auto-care.co.uk
How long will it take you to swap the pumps over, after a pump now you see?
Wouldn't take long at all can be done within a morning
I kinda just ment when will you get around to do it, I will pm u
  Xud bundle deal bosch pump fmic xudlingo 0 1,185 11-01-2017, 06:13 PM
Last Post: xudlingo
  BRAND NEW HDi HP Fuel Pump 1920 NE BiG K 4 1,537 26-09-2016, 06:41 PM
Last Post: cully
  New 306 GTi-6 PAS pump belt cover powerandtorque 0 723 26-07-2016, 09:15 PM
Last Post: powerandtorque
