Threads: 202
58
What are people using??
Ideally, I want one that looks the same as the speedo, but whatever is accurate really. I guess budget would be up to £40 ish..
Threads: 189
10
Car Model/Spec: E39 ACS 535i
Would be going for a stack one myself, but they are around the 50 quid mark.
Threads: 87
31
Only heard good things about stack and isspro, both expensive but you get what you pay for
Threads: 189
10
Exactly that, you do.
I'm going for a stack boost gauge, and a zada tech lcd system for egt, oil temp/presure and all the other featuers it offers.
Threads: 150
14
Car Model/Spec: 306 HDI
i brought one from a company called "motor meter racing" seem good enough
306 HDI, soon to be XUD
Threads: 24
I can highly recommend SW. They are exemplar quality and half the price of the ones mentioned above, for which you are just paying for a name.
Threads: 82
27
Car Model/Spec: E92 335i, GTi6, HDi S2
Quite a lot of people i know use AutoGauge ones, i have one myself.. Looks fairly OEM and as far as i know they're fairly accurate and fairly cheap too
Threads: 4
iv got an auto meter one
or a stewart warner one
both usa made and seem solid and good
Threads: 9
19
Car Model/Spec: Ph2 DT with big Snail.....
if you want factory looking you can't go far wrong with VDO gauges and they have a good reputation too!
Threads: 90
54
OEM + gauges like above are FTW!
Threads: 24
Or for half the price...
Edit: Admittedly it doesn't have as many increments but you shouldn't be aiming for half measures anyway
Edit 2: And it has the vacuum bit which is annoying but not worth paying £20 extra quid to get rid of!
Threads: 9
19
Threads: 202
58
^ This. My map is designed for 19 psi, how the hell am I supposed to read that accurately?
If i said i wanted a cheap one, then i'd look at that, but I'm not after cheap junk. (might have to increase my budget though lol)
Look at the thread title ffs.
Threads: 9
19
Jonny81191 Wrote:^ This. My map is designed for 19 psi, how the hell am I supposed to read that accurately?
 you got out of the wrong side of bed this morning Jonny
VDO it is then, get it bought
Threads: 24
Well it has 20 on it, I would assume 19 psi would be slightly underneath that :roll: Besides if a remap sets the boost to a predetermined level, can't see why you need one at all, the reason the XUD lot need them is because they have to manually adjust the boost pressure when tuning. And I can assure you that the build quality of Stewart Warner instrumentation is far from 'cheap junk' so your advice for me to take note of the thread title is invalid.
Threads: 9
19
Flynn Wrote:Well it has 20 on it, I would assume 19 psi would be slightly underneath that :roll: Besides if a remap sets the boost to a predetermined level, can't see why you need one at all, the reason the XUD lot need them is because they have to manually adjust the boost pressure when tuning. And I can assure you that the build quality of Stewart Warner instrumentation is far from 'cheap junk' so your advice for me to take note of the thread title is invalid.
The title says "accurate" and every 5 PSI is not accurate!
the HDi is exactly the same as the XUD, you have to manually set the boost on the actuator, the map has nothing what so ever to do with the boost pressure so you would need one to accurately set the boost level to compliment the fuelling supplied by the map you have installed on the ECU.
So kindly pipe down or get a clue
Threads: 24
Accurate is determined by difference of the reading of the boost gauge relative to the actual pressure; not to be confused with the level of increments on the output display. the Not my fault if your tiny brain cannot comprehend the readings without markers every 1/10th of a psi :roll:
Threads: 9
19
Flynn Wrote:Accurate is determined by difference of the reading of the boost gauge relative to the actual pressure; not to be confused with the level of increments on the output display. the Not my fault if your tiny brain cannot comprehend the readings without markers every 1/10th of a psi :roll:
and how do you intend to get an accurate reading off a gauge with no markers on it..............
Since you don't know me (and never will with any luck) I don't really see how you can make that comment and if you have to resort to personal insults when your clearly wrong then you should maybe try to grow up a bit
Threads: 202
58
mark_airey Wrote: you got out of the wrong side of bed this morning Jonny
No, just bored of the troll already.
Looks like it, where did you find that one with no vac? I can only find ones that read both ways lol.
And @ Flynn, please either talk sense or GTFO. I can't put it more politely (why am I even trying to be nice to you)
Threads: 24
mark_airey Wrote:Flynn Wrote:Accurate is determined by difference of the reading of the boost gauge relative to the actual pressure; not to be confused with the level of increments on the output display. the Not my fault if your tiny brain cannot comprehend the readings without markers every 1/10th of a psi :roll:
Have a look at the pic again. It has markers on it  Incase you are still confused I will help you; the markers are there so that you can determine what the reading is relative to the proximity of the needle to the closest number. Now stop being obtuse, the gauge I have suggested is perfectly reasonable for this man's needs and it is quite clear you are simply trying to cause an argument. So just behave  hhh:
Jonny81191 Wrote:mark_airey Wrote: you got out of the wrong side of bed this morning Jonny
I'm sorry that the thread as been taken up by a bit of back and forth by Mark and myself but I have to challenge his ignorance. I find the SW gauge perfect and the display tastefully minimalistic, not to mention far cheaper than the other brands, of which you are just paying for a name. Edit: The vac bit doesn't make a difference, just ignore it or use a black marker pen to cover the vac side on the card with the numbers on it.
Threads: 202
58
Bit the bullet and bought a stack one. Cheers all for the helpful comments
Threads: 541
124
Flynn have you ever had one of those SW ones tested?
The one thats currently on jonnys car has been tested and under reads by about 7% so he wants one thats known to be accurate.
I know a few people who have had the J3 ones like I have in my garage tested and theyer supposedly very accurate.
It matters because if the map isnt getting the boost it should be then the car smokes and wont make the power it should
