Threads: 129
11
Given 0 thank(s) in 0 post(s)
I'm planning on getting on oil cooler some point very soon but will have clearance issues with the rad and filter.
Question is, can I safely sack off the original oil cooler in place of the new one to create space or try go for a Megane oil filter which is apparently smaller?
Stage 2 XUD Sedan
Threads: 541
124
you can sack off the original cooler but it helps with warm up of the coolant.
Threads: 138
72
Car Model/Spec: Mincebus
I used the same kit on the Diablo; still sitting in my shed waiting for a decent break in the weather (and some patience on the owner's part!) to fit it!
As above though, unless the car is solely a track-car, you want it with the thermostatic sandwich plate, as the oil will overcool when you're not giving it death....
Astor 'X' 4 GTi6-
6 - SOLD!
Threads: 87
48
Car Model/Spec: Rouge vallelunga 5 door Dturbo
Given 74 thank(s) in 70 post(s)
(26-11-2012, 11:14 AM)Ed Doe Wrote: as the oil will overcool when you're not giving it death....
not a problem for you Ed, or so i've been reliably informed
