Wanted: Boost Gauge
Wanting a boost gauge prefure 30psi max (going on a hdi) would like some pipe with it as well if possible.....
As mine deiced it wants to read minus 14psi constantly lol
What you got?????
Surely you only need a 20psi gauge on a Hdi?
Thought you only went to about 19psi on stage 2?
Anyhow auto gauge tend to be fairly good on a budget, auto supplies sell them in boza.
yer 19 psi if you dont turn boost up, but its recommended to be around 20-22 psi on a stage 2 but thats about the maximum the turbo will give out i think, i would consider a 20psi one, but if i do turn turbo up i would need to find a better gauge, watching a few on ebay.....
I recommend no one use dragon garages i bought it new and its only lasted 2 month if that.
The way I understand it a good map should give you the best power on as little boost as possible?
I wouldn't bother with eBay ones, just go and buy one, they are hardly expensive.
Not sure tbh im pretty sure ppl turn they boost up on a stage 2 but I might be rong I will look in to turning mine up once I get every thing sorted with clutch etc
I've got a spare autogauge 20psi you can have for cheap?
How much is cheap? Pm me
Got one now thanks for your reply guys
  Wanted: Center Boost Gauge Pod ct-hdi 7 4,409 01-12-2015, 06:55 PM
Last Post: ct-hdi
  Wanted: boost gauge pod Chris_90 2 2,906 18-09-2015, 01:48 PM
Last Post: Chris_90
  Decent Quality Boost Gauge td163 3 3,215 20-08-2015, 01:01 AM
Last Post: td163
