18-11-2012, 07:38 PM
I heard a rumour a while ago that you can still buy pre-formed brake pipe for the 306? Is it true before I go in and ask?
Brake pipe from Peugeot
18-11-2012, 07:47 PM
some have been discontinued but give it a go mate. wear a helmet though so you dont hurt your head when you fall over!
18-11-2012, 08:01 PM
(18-11-2012, 07:47 PM)Niall Wrote: wear a helmet though so you dont hurt your head when you fall over! HAHAHAHAHAHA too true!
Stealth 3door Dturbo - In progress
http://sphotos-d.ak.fbcdn.net/hphotos-ak...6076_n.jpg
18-11-2012, 08:06 PM
Yeah true, at the moment I only need a short amount. If I made my own do I need special unions or just ones the same size?
18-11-2012, 08:09 PM
Make them yourself if you have the tools!!!
You need a good quality bench mounted flare tool, copper pipe and the correct unions. Most are m10x1 male and female
18-11-2012, 08:20 PM
I don't have the tools.
I rounded the N/S front union nut, had a look and it's really short pipe to a connection. If I do the same to the O/S then I would be pretty screwed by the looks of it..
19-11-2012, 08:21 AM
Mole grips tbh,
HDi Owner for 200k/9 years
19-11-2012, 08:54 AM
I need to buy some new mole grips, mine are ruined. Had a decent set of long nose ones but lost them
19-11-2012, 09:57 AM
I rounded a rear union but used molegrips as a removal and refitment method whilst changing the caliper. Works ok
The peugeot pre-fab pipes are available in certain locations, others you just get copper lengths appropriate for the job.
19-11-2012, 10:06 AM
I just replaced all of mine with copper ones, only cost £30 to have someone else make them all up too.
19-11-2012, 10:51 AM
(19-11-2012, 10:06 AM)cwspellowe Wrote: I just replaced all of mine with copper ones, only cost £30 to have someone else make them all up too. Weren't the rears about 6ft too long? And you ended up with spaghetti under your car
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
20-11-2012, 04:38 PM
You don't need the proper tools! We used a large socket to form the bends for my rear brakes.. A reel of copper pipe is pretty cheap and then all you need is the right size olives and union nuts
21-11-2012, 10:31 AM
Don't bother buying brake pipes from Peugeot. I ordered one under the impression they were pre formed and got a straight piece of pipe. Paid £20 pounds for it as well. After the incident I still needed a pipe for the other side so got some made up for £5 pounds and self bent it. It's easy as long as you don't try to bend them at too much of a severe angle and make sure they don't catch on anything.
21-11-2012, 10:37 AM
I tried to get some the other week and they don't sell them at all.
I was pointed into the direction of GSf/ECP/unipart and so..
Phaes 1 GTI 6 - Onyx Black
| Brake pipe failure | Mighty306 | 3 | 3,996 |
15-08-2020, 03:27 PM Last Post: ekjdm14 |
| Do I buy? rear brake pipe corroded, covered in grease or other material pipes | Charlie0 | 3 | 12,435 |
18-04-2019, 10:14 AM Last Post: Mighty306 |
| Plastic brake pipe clips | Mighty306 | 3 | 3,781 |
12-04-2018, 01:25 PM Last Post: Mighty306 |
