15-11-2012, 04:21 PM
Anyone got any special tips on how to remove that little pin that holds the fork assembly on? I have tried both sets of mole grips to no avail, it's in there solid!
damn gearbox :(
15-11-2012, 04:56 PM
Tried wd40 and knocking the pin inside to loosen it up and try and pull it out ?
15-11-2012, 04:58 PM
Yeah, knocked it in slightly, but still wont come back out. May cut it off and buy a new arm..
15-11-2012, 05:12 PM
Get a good set of mole grips and twist and pull, if that dose not work try some heat on it
15-11-2012, 05:19 PM
Mine was solid and wouldn't move, so we got the Oxy out on it.. I used mole grips and twisted on other boxes though
Fabia vRS PD130 - New daily Astra H VXR - new toy!
15-11-2012, 06:02 PM
Will try heat on it when I next get a chance.
15-11-2012, 06:08 PM
you sure youre using a decent set of vice grips?
MTFU! clamp as tight as you possibly can on the pin then tip out with hammer, always works for me.
15-11-2012, 06:13 PM
I did it proper tight, in the end it ripped the threads off the adjuster bolt! I replaced that bolt with a gearbox bolt (fitted perfectly) and got it even tighter and it just destroyed the teeth on the grips! Cheap rubbish.. I did have some good ones but they went missing a while back
Apply small amounts of heat sensibly, then rapidly cool with plus gas in the target area.
Some of them don't want to come out full stop.
HDi Owner for 200k/9 years
15-11-2012, 07:03 PM
Use the claw end of a hammer as if your removing a nail...works every time
15-11-2012, 08:54 PM
I cut the arm so could bang the pin tho. Altho I did have a spare arm lol
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead |
