Battery Relocation kit
Wanted: Battery Relocation kit
Wanting to move to lefthand side of a sedan boot. I do have 0awg audio cable but I believe that is not suitable? So anyone do them made up with a cut switch?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
I can do you one just need some measurements and details
Email me at
richardspong06@aol.com
Cheers
Don't use audio cable. Cheapest way would be to go to a scrappy and rip the battery wiring out of a BMW 3 series. They were located in the boot.
I know it's a bit pikey but couldn't you fashion some out of some jump leads?
(13-11-2012, 12:45 PM)Oil-burner Wrote: I know it's a bit pikey but couldn't you fashion some out of some jump leads?
Big No No, jump leads are designed for a short burst, the pikey who had my car before me had them as earth cables :S
[Image: J5hxCcC.jpg]
Jump leads are a no no. They weren't designed for that use just as a jumper and not too be in constant use. Probably end up killing them
*slowly makes his way to the door*
I have used jumpleads before but they just burned out. Why is 0awg audio stuff not suitable to use?
(13-11-2012, 11:56 AM)swampy Wrote: I can do you one just need some measurements and details
Email me at
Cheers
Do you do them crimped ready to fit? Will try measure this weekend but I still have interiour in so might be weekend after.
I have considered a bmw setup but local scrappys don't have any and I don't have a car to get to u pull it atm
Blaze 1.6 Dead
You can get them in halfrauds and maplins apparently!
Prob cheapest to get them from an auto factors tho tbh!
Will check ebay actually for bmw setups
Blaze 1.6 Dead
Yeah crimped and solderd , then heat shrink the ends to make it nice and neat
An in the middle of putting a kit togeather for a wire tuck job on a mk2 golf
  Wanted: Battery relocation kit Chris_90 5 4,472 02-06-2017, 07:35 AM
Last Post: welshpug
  Wanted: battery relocation kit Chris_90 9 5,839 30-07-2014, 08:09 PM
Last Post: Chris_90
  Wanted: battery relocation kit Chris_90 14 6,352 31-03-2014, 09:04 PM
Last Post: SupaStar88
