GTi6 lowering kit on sedan.
Anyone got any ideas on how low my sedan will drop if I fit the 60mm lowering kit off my GTi6 as i only want to drop the sedan 30-40mm
I remember fitting GTi6 springs to my HDi estate and it raising it about 10mm (IIRC)
Im just too lazy to do it just to test.
Surely it should drop it bud, they were standard gti springs you put on the hdi weren't they?
[Image: SDC10442-1.jpg]
Yeah but i dont want to drop it the 60-70mm it dropped my GTi6, i only want a little lower.
Standard springs raised the hdi 10mm right
Iirc the xud lump is similar weight?
Of so 60mm gti lowering spring will be about 50mm no?
As above about 40-50mm I reckon
As said dum you will prob be looking at around 40-50mm
  cabriolet springs/gti6/lowering bad2vbone 1 1,906 25-02-2014, 11:22 AM
Last Post: bad2vbone
