GTi6 engine parts
I am going to start splitting a GTi6 engine, so have everything available apart from coilpacks which have been sold. The engine has covered 140k but pulls well and isn't a tapper.
List off the top of my head:
Cylinder head complete with cams, cam covers etc etc. A non tapping head ideal to replace a tapping unit £150
Bottom end complete with internals, crank, sump etc etc. Only the external ancilleries are to be removed. Otherwise it's a complete bottom end £100
Air con pump. The air con was fully working so it's a known good unit. £20
Bare inlet manifold - £20
Bare throttle body - £15
Vacuum pump - £15
Exhaust manifold - £15
Fuel rail SOLD
Injectors x4 SOLD
Cambelt covers inside and out - £15
Power steering belt cover - £10
Aux engine mounting bracket - £15
ICV SOLD
Thermostat housing with sensors - £15
PAS pump - £25
Starter motor - £20
Alternator - £30
All pipes etc are obviously available, so if it's not listed it's because I've forgotten to list it.
Broken my fair share of GTi6's so I always have various bits coming and going so by all means enquire with any parts required.
Bianca Rallye
1989 205 GTi6 on ITBs
BMW Z4 3.0
Thousands of GTi6 parts availabile.
Don't sell ed the filter! Tongue
What mileage is on the top and bottom end?
BumpSmile
Bianca Rallye
BMW Z4 3.0
How much for the injectors posted???
Are they in good nick?? Smile
[Image: Sig3_zpscd005eb1.jpg]
(13-11-2012, 09:15 PM)Alee83 Wrote: How much for the injectors posted???
They are in decent condition yeah and fully working.
Delivery will be £4.
Bianca Rallye
BMW Z4 3.0
Bare engine and injectors sold
Bianca Rallye
BMW Z4 3.0
Cheers buddy... Wink
Bare engine is now available again. Can build up with any ancilleries you may need. Price dropped to £200 for the bare engine.
Bianca Rallye
BMW Z4 3.0
ICV gone.
Bianca Rallye
BMW Z4 3.0
Bumpp
Bianca Rallye
BMW Z4 3.0
All now in bits so will fire up a new list shortly.
Bianca Rallye
BMW Z4 3.0
Throttle body. £10 ?
[Image: Cn91r40h.jpg]
(01-01-2013, 08:38 PM)7057sam Wrote: Throttle body. £10 ?
Can do if for £15 all in delivered Smile
Bianca Rallye
BMW Z4 3.0
Got standard air box and piping?
[Image: signiture.jpg]
Not got any standard air boxes but have a good snorkel and a couple of elbows. Although the inlet elbows have the usual split ICV pipe joint.
Bianca Rallye
BMW Z4 3.0
Updated list:
Bare inlet manifold - £20 Reduced to £15
Bare throttle body - £15 Reduced to £10
Power steering belt cover - £10 Reduced to £5
Vacuum pump - £10
Map sensor - £10
Inertia fuel cut off switch - £5
Starter motor - £20
Alternator - £30
Top rad hose - £7
Injectors x4 SOLD
Coil packs x4 SOLD
Air con pump. NLA
ICV SOLD
Fuel rail SOLD
Fuel pump relay SOLD
TPS SOLD
PAS pump SOLD
Head SOLD
Bottom end SOLD
Just come across a crank sensor in GWO - £8
Bianca Rallye
BMW Z4 3.0
More parts sold. Updated list.
Cambelt outer cover - £10 Reduced to £10
Vacuum pump - £10
Map sensor - £10
Crank sensor - £8
Starter motor - £20
Alternator - £30
Injectors x4 SOLD
Coil packs x4 SOLD
Air con pump. NLA
ICV SOLD
Fuel rail SOLD
TPS SOLD
PAS pump SOLD
Head SOLD
Bottom end SOLD
Exhaust manifold SOLD
Power steering belt cover SOLD
Top rad hose SOLD
Bianca Rallye
BMW Z4 3.0
Bump.
Also got various other small engine/engine bay odds and sods like a few breather pipes, chocks, mounting plates etc etc. Try me.
Bianca Rallye
BMW Z4 3.0
Bump Big Grin
Bianca Rallye
BMW Z4 3.0
  Few gti6 parts Blandy 5 3,576 17-03-2016, 08:03 PM
Last Post: Blandy
  G-I Circa 200 Bhp N-A Gti6 Engine welshpug 17 7,761 20-12-2015, 09:34 PM
Last Post: welshpug
  Rallye/GTi6 rear beam parts.... Ben_w 2 2,410 09-12-2015, 10:46 AM
Last Post: Ben_w
