09-11-2012, 02:21 PM
About to fit an oil pump, got a choice of two. One makes significantly louder clicks when the sprockets turned. Does this suggest one is better than the other?
![[Image: 20120704_212316.jpg]](http://i789.photobucket.com/albums/yy175/DanHargrave/20120704_212316.jpg)
Which oil pump should I use?
09-11-2012, 09:29 PM
Take them about and see which one has worn the casing more / has more lash....specs are in haynes if you wanna be anal...clicking means nothing, as one could be dry and one wet with oil...
| #DervMafia | ![]() |
