Oil Pressure & Temp Gauge
Yo everyone!
just brought myself a set of gauges, and i am unsure of..
Oil pressure fitting thread size & location
Oil temp fitting size & location
i have a ph1 dturbo, with no oil temp on the clocks (it is oil temp aint it Undecided ), <- if correct, im thinking oil temp, shouldnt be to hard?
As there should hopefully but connectors/plugs somewhere on the engine to wire the gauge too?
Anyway, thanks in advanced for all your advice!
Mike
You'll need a sandwich plate to go between the oil filter and the block. About 15 quid on eBay
My oil pressure guage goes straight into the engines standard oil pressure senders hole. As it has a very large fitting, then oil temp is on a sarny plate as said
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Thanks guys!
.....Ignore my first top post.....
Coming to fit my gauges now, i still havent got much of a clue where to get the signal for the oil pressure and temp :/
Any help would be much appreciated!
Mike
Question which sensor feeds the temp gauge? Mattcheese31 4 3,498 23-03-2016, 12:18 AM
Last Post: Mattcheese31
  Exhaust Manifold Pressure gauge install HDIkyle 19 13,928 30-06-2015, 08:51 AM
Last Post: mr_fish
  Temp gauge raising Danaidh 14 6,061 06-05-2015, 05:02 PM
