04-11-2012, 08:43 PM
Mine don't work is this a common problem the button on the dash lights up but the window Wong heat up is there a solution ?
Estate heated rear window
05-11-2012, 04:06 AM
Mine did this a while back mate, turned out to be the relay.
05-11-2012, 07:51 AM
Where is the relay located ?
05-11-2012, 04:36 PM
By the fuse box under the steering wheel mate........it's the orange one top RHS
05-11-2012, 06:32 PM
Is there anyway I can test it without replacing it
06-11-2012, 04:12 AM
Not a clue mate, I'd ruled out everything else when mine went but there was no power getting through to the screen so changed the relay and it sorted it........got mine from a breakers for pennies.
17-04-2013, 04:01 PM
Digging up an old thread but this is now one of the last 3 things that need repairing so I wanna sort it out
The switch lights up when depressed The relay clicks when I press the switch Can anyone tell me where the connections are for the window so that I can check if its getting power I can't see them anywhere
check the fuses as the heated mirrors are controled by the same relay and door looms break shorting and poping the fuse
http://306oc.co.uk/forum/thread-11549.html
17-04-2013, 04:20 PM
I ain't got heated mirrors on my car I repaired the door loom in march I think it was well replaced it not repaired it
17-04-2013, 04:28 PM
The wiring connectors for the tailgate are actually under the roof lining near the back, might be a bad connection there somewhere.
17-04-2013, 04:39 PM
Oh right ill have to look there then where are the ones for the strips in the glass though
17-04-2013, 08:20 PM
Erm, follow the lines lol, they've gotta be at one end somewhere!
Its easy to see on SRowells as his had a new window, looks like they bent some of the metal to get to the copper ends.
17-04-2013, 09:24 PM
They arnt on the glass anywhere I can see unless they are below the plastic panel at the bottom of the window
17-04-2013, 09:32 PM
Hmm, I can have a look at my.old tailgate tomorow, plastic is already off anyway. But I've got an idea its one side, could be wrong though, might have been a different car lol.
17-04-2013, 10:03 PM
If you could look I'd appreciate it my old cars have always had a spade type connector on the glass
18-04-2013, 02:59 PM
Have you had chance to check this mate ?
18-04-2013, 03:09 PM
Have you checked the loom from body to tailgate, the wires in there break all the time like the door looms
18-04-2013, 03:15 PM
I can't see any splits on either side of the tailgate
My rear wiper and rear washer don't work either
18-04-2013, 03:28 PM
18-04-2013, 03:41 PM
(18-04-2013, 03:15 PM)Willo Wrote: I can't see any splits on either side of the tailgate The rubber boots wont be split, be the wires broken inside.... If the wiper dont work either, I would head for fuse or wiring in those looms Wishes for more power...
18-04-2013, 03:46 PM
I'll check all the fuses tommorow
I pulled the gaiters back I can't see any splits in the wires
18-04-2013, 09:18 PM
Checked my tailgate today, the copper tabs are underneath the plastic at the bottom of the glass.
18-04-2013, 09:30 PM
Cheers Tom ill get hold of a multi meter at the weekend and check see if there getting any power through to them
18-04-2013, 09:41 PM
If your tailgate plastic is like mine it'll be easy to remove, there was only one screw left in it!
18-04-2013, 10:29 PM
There's about 5/6 screws in mine ill have a look over the weekend and see what's happening behind there
| Wiring diagram for heated seats | bebic | 0 | 3,175 |
28-04-2019, 07:30 PM Last Post: bebic |
| electric / heated rx8 seats | ash23 | 6 | 4,674 |
07-12-2014, 02:18 PM Last Post: ash23 |
| Heated Rear Window Relay | Mark | 6 | 4,379 |
05-11-2014, 02:22 PM Last Post: cully |
