throttle shaft leaking fuel
hi my throttle shaft has started leaking fuel not much but its there cars done over 200000 miles so probaly down to age not the vegoil i was using (now on straight derv) i understand how to mark the levers and remove the lid but do you guys change the brass bush or just the oring ( is there one or 2 on the shaft) many thanks for any advice tips cheers
Dont know what your on about with the brass bush but im pretty sure its one o ring. Smile
Edit: Just the one
[Image: 20120101_231237.jpg]
thats the one! the bush is pressed into the lid looks brass? not sure if these wear? theres a repair kit on ebay
http://www.ebay.co.uk/itm/160904787514?s...1438.l2649
i think 1 o ring is for the shaft one maybe for the cold start shaft thats in the top lid? then the new bush tube? not sure what the big black round ring is though and will these be ok for veg oil?
change the o-ring on the throttle shaft and you should be fine
cheers stevieg so i just need to get 1 oring and the lid cover gasket then? will try a bosch dealer later see if there cheaper than a kit of ebay
you can get a full seal kit for £16 on ebay http://www.ebay.co.uk/itm/BOSCH-VE-Turbo...3f1e442395
pick the seals you need and if any other leak over time you have them there
What he said really, just swap out the O ring, the tube can wear, but generally not much, and will be fine as is....some of the pumps have two o rings, which are better for this!
are the normal bosch seals ok for veg oil? as i been reading up and these o rings are supposed to be realy good for bio/veg and heat
http://www.ebay.co.uk/itm/221134881186?v...1438.l2649
cheers guys for the advice
  Bosch Fuel Pump governer shaft (spline)please HELP! Dantheman1312 10 5,560 05-07-2016, 07:19 PM
Last Post: Piggy
  Bosch fuel pump leaking badly andyyy 32 16,625 13-01-2014, 10:55 PM
Last Post: andyyy
  gearbox leaking at shaft john85cw 3 2,670 15-08-2013, 09:25 PM
Last Post: Rich306
