Middle box to backbox info
I got a mid section of a 1.6 8v and was funna use it for a backbox on my hdi but puglove has made a good point of petrol exhausts made to give back pressure can is it still safe to use for a back box or do I need a hdi midsection to modify ??
Don't use anything from a petrol unless it's supra lol, they're just too restrictive, will ruin your spool and cut off your top end as well.
Bad times :-( ill start looking for a hdi centre box
The midsection will still be a straight thru design, but will likely have a diameter of about 2 inches or something daft, thus being restrictive. It's only the.back boxes that have the baffled, restrictive design. A centre off a gti or an xsi would probably work, as the bore is larger.
I think the gti's have 2" dia, the 1.6 pipe i had floating about was even smaller than that. As a guide; the HDi std item is 2.25", so anything smaller than that will be restrictive.
Gtis are same as the xsi, 2.25, I *think* parts of the cat might even be 2.5... But don't quote me on that lol
Oh fair enough, didn't realise that, could be sweet then.
Indizzle! Also, pood, what you up to this weekend? Text me Wink
Ohhhhhh what are you planning? Tongue
(31-10-2012, 12:17 AM)Matt Wrote: Ohhhhhh what are you planning? Tongue
Not getting jelous are you mathew?
Face it Mickey, the way you've been going it's like throwing a sausage down a tunnel, time for sammy boy to trade in for a fresher model.
Hahahaha!
  Middle box delete and crank pulley allye 27 14,239 29-10-2016, 06:41 AM
Last Post: allye
