Threads: 541
124
Hi all the revs on my 2.0 16v cabby are hanging quite badly when i let off the throttle. If i rev the car to 2500rpm it takes about 5 seconds to return to idle.
Its been doing this since i got it, hot or cold and ive just swapped to a GTi6 manifold using all the GTi6s sensors and this hasnt changed a thing.
Im feeling that it might be worn injectors still letting a little fuel through but really i dont have a clue.
Threads: 448
51
I have the same issue, since I fitted the gti6 manifold it's made it more noticible
Threads: 48
I had this issue when fitting the gti manifold to my XSi
Threads: 541
124
It was doing it on the XSi manifold though too
Threads: 448
51
Mine did it on the xsi manifold, but is now more obvious now fitted the gti one
Threads: 80
10
You checked the easy ones like sticky throttle cable? Airleak? Did you put a new gasket on it?
Serious.
Given 81 thank(s) in 77 post(s)
Mines always done it since ive had it on two different sets of injectors. I also know that both of grants have done it and the car we bought for spares did it. Think it's just a pug thing!
