Threads: 136
2
Car Model/Spec: Phase 2 Dturbo
Given 1 thank(s) in 1 post(s)
I've got the dash out at the moment for matrix replacement, and thought I'd try and fix my heating at the same time. I thought that the heating temperature control knob would be connected to a mechanical cable, but its not so I guess it must be electrical.
Can anyone suggest something I could check to see if the control knob is working? I'm crap with electrics so have no idea.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
Its a mechanical cable, maybe its popped off already - sometimes people who have done the heatermatrix in the past can snap off the mounting points for cables and generally break stuff bodge stuff back, which is a right pain when you come to fix it :/
Threads: 0
45
It's not a cable Ben, it's sensored, you'll find a small fan type thing in the roof console - probably full of dust! My ph3 has this anyway
Threads: 142
58
Car Model/Spec: E46 BMW 320d
My Ph3 had a cable...and the fan thing in the ceiling...
Threads: 52
1
Car Model/Spec: Ph2 Dturbo
afaik A/C is electric. NON A/C is cable
Threads: 142
58
Mine was A/C, and had a cable.
Parts bin speacial maybe. Had 1.6 brake setup too, despite it was only a 1.4.
Threads: 581
195
Given 81 thank(s) in 77 post(s)
If your heater controls have a 1, 2, 3 and 4 for fan settings, i cant help you.
If youve got the 'climate control' where you have a auto setting, its all servo controlled except for the dial that switches where the air is put out from. this is controlled by a yello and green cable.
Check the fan on the ceiling is clean and plugged in. If not, could be a faulty servo (hope not.....thats a matrix apart job) or faulty control unit.
Threads: 136
2
Yeah I've got the 'climate control' one so ill check the fan. I've just replaced the matrix and the dash is still out so i shouldn't think it would be too much more work to do the 'matrix apart' bit. Although I would like the car in a couple of days so it'l just depend how long it'l take me.
Threads: 136
2
Just found the fan in the ceiling, why is it there? It's plugged in but not sure how to test it further.
Where abouts is the servo, I might try replacing that and then replacing the control unit if that doesn't work..
