Wipers don't auto park :(
I've got my MOT coming up in a few weeks and my wipers won't auto park. Think this is an mot fail and need to get it sorted ASAP. Are there any quick fixes or do I really need to replace the wiper motor etc. I've changed the stalk for a known good one so I know that's not the problem.
Take it apart and clean it, or swap it
I'm pretty sure thats a failed wiper relay issue. I think it's under the dash and do things like turn on lights and open door, switch on indicators etc to rule out which relays aren't the wiper relay.
Ask around incase it's something else but it's worth a shot.
My hands are too painful to be taking stuff apart and messing about - gonna have to get someone to change the wiper assembly/motor over for me as it is unless its the relay. Will check that in the daylight.
Right I've checked all the relays and it looks like its a motor issue Sad
Are all motors the same? i.e. will the motor from a car with rain sensors fit one without?
Yep all the motors are the same. Get someone to take the cover off it, clean up the tracks and regrease. Much cheaper!!
Cheers bud - any special grease - only got this stuff [Image: de2y4ede.jpg]
Will it be ok?
No you don't want that mate (I don't think) its a case of removing the wiper assembly which involves firstly removing the scuttle panel plastics then the motor bracket, opening up the motor itself by removing the back plate and then cleaning up the 3 contacts inside. I would worry that copper grease could conduct? Which you don't want to happen. Little bit of sandpaper or a small file will do the trick.
I really must do mine as I have the infamous nervous-wiper judder.
[Image: Sig500x130.png]
Just smear the copper tracks in Lithium grease
Niall, would moly grease work? I have to do mine soon and that's all I can find in my toolbox!
(26-10-2012, 04:20 PM)c.a.r. Wrote: Niall, would moly grease work? I have to do mine soon and that's all I can find in my toolbox!
Cant see any reason why not! Only reason why i didn't like the idea of copper slip is as you said, its a conductor!
I have some Vaseline will that work? - I've got plenty of that...............
awaits a comment from Samass Smile
(26-10-2012, 04:23 PM)ash240970 Wrote: I have some Vaseline will that work? - I've got plenty of that...............
Errr tbh its not something ive ever considered. If ive ever needed grease, ive always just gone and bought it seeing as a small tube an be had for a couple of quid!
Yeah I know but I bought the Vaseline to go on the rear light cluster rubbers to stop the leaks on my ph1
Oh dear, I've managed to get rear, rubbers and Vaseline all in one sentence :0
Stop being a tight northerner and go to halfords and get some grease!
I'll have you know I'm far from tight and far from Northern - calling people names because of where they come from sounds slightly racist to me - you're beginning to sound like SRowell.
Proud to be British and driving a car built in Britain!
Now there is a valid point - where the hell would this forum be if it wasn't for the workers of the Midlands building our beloved 306's.
Oh yes I forgot because I'm from the Midlands I'm a Northerner to you - well that's fine as long as you don't mind driving round in a car built by us Northerners.
Next time you describe your car as French i'll be the first one to correct you Tongue
(26-10-2012, 05:05 PM)ash240970 Wrote: I'll have you know I'm far from tight and far from Northern - calling people names because of where they come from sounds slightly racist to me - you're beginning to sound like SRowell.
Anyone can bolt a engine in a shell. R&D on the other hand is a special skill done in....errrm france!
Your argument still holds no validity as far as I'm concerned as i said built not designed and I've found some lithium grease in the garage so I can continue to be 'careful' with my money.
I spent £19 in Halfords wednesday so they're not getting any more of my money for a while.
Shudder to think how much more you would have got for your money at another motor factors other than halfords though!
I don't - the town I live in is crap and the only motor factors here is shite - it used to be good back in the day when it was A1 motaparts but now they've hardly got any stock in, most of the stuff they sell is cheap Chinese stuff and heavily marked up and the branded stuff they do sell is as cheap or if not cheaper at Halfords despite it being a 15 minute drive to Halfords otherwise its Bromsgrove motor factors for me cos this place in Droitwich is so bad I'd rather shit in my hands and clap than give them my money.
Right this is all sorted now thanks to R45 ODV - big thanks for your help on Sunday Smile
Was it the motor contacts in the end?
(06-11-2012, 12:44 AM)ash240970 Wrote: Right this is all sorted now thanks to R45 ODV - big thanks for your help on Sunday Smile
No worrys mate
(07-11-2012, 07:02 PM)c.a.r. Wrote: Was it the motor contacts in the end?
I would say yes just swaped the motor out and replaced it for a known good one and its all working now Smile
We don't know and don't give a flying fcuk - we (R45 mainly)just swapped the whole assembly over c/w motor for another one as it was feckin cold and rained all morning right up till about 1 o'clock and he had lots of people turning up for parts at his all day. Oh yeah and my scuttle panel is a bit more fiddly as I have my washer hoses coming through it so he just whipped the lot out and chucked in the one from the 6 he's breaking.
Beat me to it again lol
mine took the knock also with the one-touch wipe;
wipers stopping as soon as you let go of the stalk, i took the motor off yesterday and found that the brass contact nearest the centre of the motor had broken off. after cleaning out all the old grease which had turned to mush !!! i bent the remaining bit of contact down so it was level with the 2 un-broken ones. repacked gears with fresh grease,refitted and now it works.
i think the fact that the wing drain under the motor was blocked meant the motor has possibly been sitting in a pool of water until i cleared the drain out last month when i repaired the linkage that kept popping off.....?
  How to disable auto wipers bashbarnard 8 5,241 09-04-2016, 08:25 PM
Last Post: Piggy
  Retrofitting Auto Wipers RetroPug 6 3,851 06-08-2014, 04:04 PM
Last Post: RetroPug
  Auto wipers philpemberton94 12 5,868 05-08-2014, 04:30 PM
Last Post: RetroPug
